F6 Amplifier
F6 Amplifier
Old 16th January 2013, 02:06 PM   #3491
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
Originally Posted by Botte View Post
@botte: how much db did you choose k2 over k3, please?
~10dB at 1 watt, is where it's at with no trimming.
thank you Botte!
I can get this value also without using degeneration by choosing the right pair....!
But first I want to play the distortion tango!
and the First Wtt is......a really First Class PSS Idea
Old 16th January 2013, 04:21 PM   #3492
flocchini is offline flocchini  United States
thanks generg for the information. Working with the F6 is like doing experiments in the lab. Control those variables
Old 17th January 2013, 06:48 PM   #3493
lhquam is online now lhquam  United States
I tried just matching transconductance but some other parameter(s) that was not being measured was also important. I suspect that it is the internal source resistance of the SS-R100.
Originally Posted by generg View Post
O.K......
it took me some hours to find out of my 8 R125 the two pairs that gave me around 0,012% THD and a distortion spectra where k2 and k3 are at the same level.
I wanted this position to go later more easily for negative and positive phase.
If it is possible to find the pairs only by measuring the transconductance of the parts outside of the circuit then I am an idiot.....not to build the circuit Nelson suggested 1993...!
So buzzforb and tea-bag can measure the transconductance, so it would be very interesting to see, if they get a predictable distortion picture.
Tea-bag please insert in your F6 two pairs of SS with same transconductance and let us see the distortion picture. k2 should be reduced, shouldn't it?
Buzzforb can you see distortion?
and of course Ihquam did you see a correspondence between equal transconduction and a reduced k2 compared to k3?
when my 10 Ohm pots are coming I will continue....
because changing the source resistors changes as well the bias, as the offset values...... ! Too much work! Am I correct to suppose that using the pots the bias and the offset is not changed?
Gute Nacht!
Old 18th January 2013, 02:43 PM   #3494
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Here is a paper I haev had for a while. It may be of interest to some.
http://socrates.berkeley.edu/~phylab...Files/bsc4.pdf
If I get a chance, i am going to measure each of my 8 SS using both the curve tracer and the meothod above to see what we get. According to the paper above, both simple test should yield similar results.
The theory put forward so far is, that a jfet with lower yfs(transconductance) up top compared to bottom fet, should yield higher k2 to k3. With the same yfs for both top and bottom, cancellation of 2k is ecpected, as well as lower overall distortion. If this proves true, then it should be easy enough to work things out for higher K2 to K3, even using no degeneration(which I like best), if we put lower yfs fet up top. To get higher K2 up top should be easy if we add source degeneration, as we can alter the yfs of the top fet, yielding higher K2 even with perfectly matched pairs. There is some question as to whether the aforementioned threory is actually proving valid or if there is something else at work. We shall see.
Oh yeah.
This may take a while.
...Shape the sound , Man!
Old 18th January 2013, 04:51 PM   #3495
thanks for the UCB lab reference
Old 18th January 2013, 05:13 PM   #3496
Antoinel is offline Antoinel  United States
F6 Amplifier
Something screwey about it. Saw front page only[out of 23], and it froze the computer requiring a restart; twice.
Old 18th January 2013, 05:15 PM   #3497
buzzforb's Avatar
Loaded perfectly for me.
Old 18th January 2013, 05:17 PM   #3498
also loaded for me
Old 18th January 2013, 05:56 PM   #3499
flg is offline flg  United States
flg's Avatar
Well, I'm an impatient type when it comes to putors. It just took a minute A MINUTE!!!
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 18th January 2013, 06:00 PM   #3500
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
lazy greedy boyz ...........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
