F6 Amplifier
I am always erring around,
anyway I found these depletion mosfets:
At around 2 amps they need some Rs but then they are fine
1) IXTH6N50D2 Stable with 1.1Ω, Ciss = 2.8nF; at 4.5S ; Stable (Example Rs 0.5Ω+0.56Ω; 1.2Ω//20Ω). Good tempco ... € 13/Mouser
2) IXTH16N20D2. Ciss = 5,5nF Vgs = -2,2V @ 2Amp, 12S; Ron 80mΩ Take a Rs=1Ω or 1.2Ω €22/Mouser. Slight pos tempco, but with such a Rs that is moot.
The second looks like a powerhouse to me. The first one looks very useable too.
How to simulate these? Any models floating around? Any on-hand experience?
With these, it looks like the 'original' F6 with R100 looks like obtainable!
I totally agree. all degeneration will destroy the vibration.
and putting a big .1 - 1F across it helps little probably.
note the F6/IRFP has 0.47Ω or 0.56Ω.
This beast has 1Ω. What is the difference?
here the degeneration is as variable as the sloppy drawing of a potmeter to its wiper the capacitor is attached.
top = little; bottom a lot (up to 1 or 1,5dB difference) - theoretically impossible to hear.
or have the other half use this; enfin you know the trick.
A bias V- would be more comfortable and is easy to make for the top. attach a green led (yes green please!?) to earth and the V- and presto you have some -1,7V bias for the wiper to scratch. :scratch: Or a fixed-Voltage-device of 2.5V .
Then no degeneration on top.
But then you will have to test the harmonics of the whole with only degeneration at the bottom. . and that might switch the phase around (It is all in my head now, sorry)
thanks. Twitchie.
And now we are at it, I must say the Rs is not a source resistor at all, mostly with EUVL's potmeter, to some extent.
The Vgs derives from the transformer winding, and the top unit 'amplifies' by pushing current across that 0.47Ω (or 0.56Ω) and into the load of 8Ω; just like the bottom one (where the load is the output without a 0.47Ω resistor in between! And that 0.47Ω on the bottom is totally OUT OF THE LOOP.)
BOTH are a common-source amplifier; this is a balanced amplifier. Essentially 'equal'.
the TRICK is to make them just a bit unequal, imho statically, such that the 2nd harmonics can be changed. I call it skewing.
Because I had an amplifier where I could skew the DC points, and I observed the changes.
The French writer Héphaistos wrote about it in the magazine L'Audiophile. I did not understand what I did. I just did. Like so often.
As to that IXTH depletion device, it is much more like the IRFP than a power-JFET. So it is much ado about nothing.
But it does have great tempo; and can be run with say as low as 0.1Ω safely I assume. Looks like fun to me! No "Zenner's".
as I see it, you have both mosfets degenerated
simple as that
resistor can be "out of the loop" when looking at modulation (input side of part), but it is still heavily adding to intrinsic impedance of part ........ and that is important in context of output side of part
ZM, I like to frame it differently, because this is a fake circuit. [Nelson, I hope you do not mind this allegation...]
Even though I misused the D-word obstinately.
The way I can formulate it, is that from a loading point of view, the two resistors are in the drain path or the virtual drain path, forming a smallish voltage divider before the feedback takes its signal.
So the output impedance is raised this way more than anything else for the moment.
There is no degeneration of either of the sources , as long as the transformer coils are 'earthed' at the source pin; that is, when the coupling cap ends there.
The Vds changes and hence the characteristics, and if done well - such as with the choosen 0.56Ω and 0.47Ω - then the harmonic signature changes, in amount and phase.
EUVL's trick is nice that it allows the staff here online with true analogue distortionmeters to see the effect.
[But like said, seeing it change does not warrant bliss, as there is a lot of know how above know why involved.]
But
For those who have not suffered the audio file, the question will arise about
the degeneration.
a) Like with regular feedback, I use it only when it furthers my purpose
b) Undegenerated outputs on this circuit extend the class A region at the
specified bias by about 75% more.
I have suffered [from?] the audio file. 🤔
And. The being un/degenerated I read as "being part of the input loop".
OK Needs a picture. Vgs and Vds are 'the only' determinants of output. If this is hard to see, I'll have to redraw the whole such that the hole is visible.
As a reminder, in the US they say "Watch the donut, not the hole'
of course that we both have it right, and difference being in semantic
my sin is not writing clearly what I meant - by my opinion, there is no use of chasing Wonder Part, if price paid is introducing grater series losses; plenty of reasons to avoid that, but no use now to line them all up
I know that I'm introducing series losses in every of my amps with SQL OS, but as I'm using 0R11 resistor groups as sense for biasing circuit, there is effectively 55mOhms as addition, and even about that I lost some sleep, toying with idea how small I can make that and still being effective
but, that's no reason to let me spoil your fun ......... just go for it :clown:
