F6 Amplifier
F6 Amplifier
Old 12th January 2013, 03:06 PM   #3421
6L6 is offline 6L6  United States
6L6's Avatar
F6 Amplifier
Originally Posted by Zen Mod View Post
frankly - I don't need more amps - (almost) everything is good enough , while music matters most
Nobody really needs more than one, unless you active crossover...
But that doesn't stop us.
My queue is currently 4 amps deep;
F5T v2 for the official build guide
F4, also for the build guide
Aleph J, on new PCB, (currently in limbo, but should get going soon enough)
F6 with Cinemags and R100, as I have a set of R100...
Yes. I am crazy.
Ain't DIY grand?
Old 12th January 2013, 03:07 PM   #3422
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
@ Antoinel -as I said - long rope
nothing fancy - due to nice tempco of Sony Vfets - it will be something simple as just two additional rails up and down , simple shunt regged to some ++ and -- 25Vdc , then resistive dividers to gates
edit - due to recent xperience with venerable Sony TA-5650 , I despise voltage multipliers even more .......
so additional rail will be based on proper separate windings , or separate small xformer
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th January 2013, 03:07 PM   #3423
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F6 Amplifier
Originally Posted by buzzforb View Post
The onetics was sharp to my ears, but when adjusted for second seemed to blend really well into nice mixture. Try it out.
It all becomes very subtle work of intuition, mixed mildly with science.
One has to let go of assumptions and listen deeply, yet try to be scientific enough to look at the data, and repeat actual tests.
I agree with your Onetics evaluation totally. By default I think it's the most honest one of the group regardless. But this will not appeal to everyone!
The scope measurements of all three look real close. So it's the JFETs making the major differences I guess. But you can clearly hear differences in all types I have tried - Onetics, Jensen and Cinemag.
Old 12th January 2013, 03:13 PM   #3424
Zen Mod's Avatar
F6 Amplifier
Originally Posted by 6L6 View Post
Ain't DIY grand?
that , sort of copyrighted , smiley is always confirming that
Old 13th January 2013, 02:05 PM   #3425
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by Nelson Pass View Post
ZM has been nagging me for information on the F6. I have a very nice
sounding prototype, but the design and the article that accompanies it
have some details remaining.
However, I can afford to put out this teaser:
Zen Mod: It is time to ask Mr. Pass to release a teaser on F7. F6 has been well characterized and thoroughly undestood. A gold mine which has been almost exhausted. What next to re-ignite a buzz like that experienced with F6?
Old 13th January 2013, 02:23 PM   #3426
6L6's Avatar
F6 Amplifier
In al honesty, let's get a few more F6 'back from the wild' so to speak, and make sure that the first production PCB (tea-bag's) is rock solid. There a ton of variables in this amp... Let's make them and document it.
And also, let's not forget that the F5Turbo is just now starting to make it into the hands of the end-users and that design could use a bit of learning and 'production savvy'
And... The AB100 was just released, and it's going to need a bit of community support to update it to commonly available parts, and make a PCB, etc...
As much as I would love to see the F7, and believe me, I would love to, there is plenty of Pass design that could use community support.
...I'm just sayin'...
Old 13th January 2013, 02:47 PM   #3427
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I am full for the year
...Shape the sound , Man!
Old 13th January 2013, 03:28 PM   #3428
F6 Amplifier
Thank you for your post. Please clarify AB100.
Old 13th January 2013, 03:33 PM   #3429
6L6's Avatar
F6 Amplifier
Ok -
AB100 Class AB Power Amplifier
Old 13th January 2013, 03:52 PM   #3430
flocchini is offline flocchini  United States
I'm with 6L6 on this - there are a ton of variables with the F6 - I feel just because I have it running that doesn't mean I have something yet to discover. Being able to look at distortion spectra is only a set of probes away and they are in the mail (literally)
Also Zm has teased us with his VFet comments
"I'm thinkin' of F6 lookalike with 2SK60 and 2SJ18 ( so having complementary pair of VFets) , using 600:1200s ( meaning 150+150:300+300) repeater .
logically ,connected as 150:300+300 , having some 3db in xformer phase splitter itself
but , that's on loooong rope , having at least 3 projects tied on same line"
I'm going to see if by looking at Mike R's SIT pieces I can figure out how to incorporate the bias supply based on the 15V transformer and integrate the Sonys in the F6 circuit. Never have done this but it would be worth the learning curve or
maybe it will move up ZMs line
Best
Bob
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
