#3351 |
dont you need a cap on secondary connection to prevent DC
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#3352 |
The FET's are going to be in the Meg Ohm range, and there is no other path through the secondaries. So it isn't going to bother the transformer, if thats your concern.
It may be useful to have the upper JFET with an adjustable bias and AC coupled to the output, but I don't feel its necessary for operation.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
#3353 |
I think R1,2 and 3 and R1,2 and 3 need to be about 1 ohm not 2 ohm! And, that +23v on the top, needs to be about +60V
Of coarse you will need the appropriately sized sinks...Otherwise, I like it!
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#3354 |
Fig,
Can you explain why does the Vcc need to be +60? In the F3, the extra voltage was there to bias the active load. Doug
#3355 |
I like your sig and Monty python.
#3356 |
More Vcc allows for more output voltage. More Iq allows for more output current
![]() Gain might even increase slightly so you have the option of lowering F.B.
#3357 |
More is better!
With the Cascode, it shouldn't change much.
#3358 | |
Best regards. |
#3359 |
Antoinel,
Thanks for the explanation. I am going to have to think about this some more. ![]() Sounds like other topologies are more cascode suitable.
#3360 | |
Best regards. N.B. Will a darlington instead of a MOSFET be suitable? One may be able to getaway with a Vcb ~1.2 Vdc for more output power with lower power rails. |
| New F6 diy coming soon ? | Nounours18200 | Pass Labs | 37 | 31st August 2012 04:35 PM |
| Hi Vi F6 box | ioro | Multi-Way | 4 | 15th April 2012 08:27 PM |
| Whats happening with F6? | jugoslavija | Pass Labs | 1 | 1st November 2011 07:39 AM |
| Hi-Vi F6 | kkosiba | Multi-Way | 14 | 9th November 2007 08:38 AM |
| F6 | traw | Pass Labs | 7 | 2nd November 2007 07:09 PM |
