F6 Amplifier - Page 330 - diyAudio
Old 14th December 2012, 09:17 PM   #3291
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
nothing is stopping you from testing it
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th December 2012, 09:30 PM   #3292
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I completed F6 with IRF240's.
I used 1R Source resistors. The bias only went to ~500mv with existing 5K Pot.
Assuming I go, to .5R resistor, I think this will give me enough room to bias higher. I was too scared to add pots across the source resistor. With IRF240's I am not sure if that's a good idea, assuming the overall source resistance goes below <.5R overall.
If not I was considering changing R3-4.
Any thoughts?
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Out of stock
Old 14th December 2012, 09:41 PM   #3293
Zen Mod's Avatar
LED voltage is culprit
what you're using - blue ones , how many in series ?
and - what voltage you're getting across them ?
Old 14th December 2012, 10:01 PM   #3294
Thanks to Tea-Bag for his high caliber supplies; R100A and the upcoming PCBs. I am slowly following your recommendation.
Old 14th December 2012, 11:12 PM   #3295
Tea-Bag's Avatar
ZM - did not even think of that! The only thing Papa asks us to measure
It's 4.05v using one blue and one red Led. I will try two blue ones.
Old 14th December 2012, 11:14 PM   #3296
Tea-Bag's Avatar
Special thanks to Buzzforb , who's Onetics transformer is in action here.
Old 14th December 2012, 11:17 PM   #3297
Zen Mod's Avatar
next time you put something funny in tea bag , call to share
Old 14th December 2012, 11:27 PM   #3298
Zen Mod. Here is what astounds me by using this example:
  • 0.1% H2 is 1 sine cycle of H2 in 1000 sine cycles of the fundamental H1.
  • The amplitude of one H1 in a reference 2.828 Vrms into 8 Ohms [or 1 W] is equal to (2.828 /1000) = 0.00283 Vrms.
  • If the amplitude of one H2 cycle is equal to that of one H1 cycle, then the answer is 0.00283Vrms across the same 8 Ohms simultaneously stimulated by H1.
  • What is the output power attendant to H2?
  • P{W} = [V X V]/8 = 1 microWatt.
  • But fortunately; human hearing is 1000 times more sensitive in detecting H2 than H1 [just playing with working numbers].
  • Thus, the actual output power from H2 is 1 milliWatt.
In my previous post [Class A/B diyF6], I wanted to raise the power level of H2 to 10-100 milliWattsi in 1W total output power. Afterall, H2 is a desirable distortion; within limits.
Old 15th December 2012, 12:25 AM   #3299
Tea-Bag's Avatar
Two Blues give room to bias up much higher. Measures closer to 4.25v now.
I just used two random IRF240's, no matching tried. Offset still good. I will try some matched Fairchilds in the other channel.
Old 15th December 2012, 12:35 AM   #3300
lhquam is offline lhquam  United States
Good looking boards. Yup - you need to put LEDs in series or use zener diodes up around 6 volts.
Any thoughts?
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
