F6 Amplifier - Page 325 - diyAudio
Old 10th December 2012, 02:32 PM   #3241
Originally Posted by Tea-Bag View Post
Yes, @ 120mm from screw hole of power Fets.
lhquam, permaneder and Tea-Bag: Which chassis(s) in our DIYAudio Store will accept your PCBs with no additional modification?
Best regards.
Old 10th December 2012, 02:42 PM   #3242
Best regards.
I do not understand your question. Just drill holes into the heatsinks and cut threads, e.g. M3 = 3mm, or any " equivalent
Old 10th December 2012, 02:44 PM   #3243
6L6 is offline 6L6  United States
6L6's Avatar
What he is asking is if your PCB will fit the heatsinks with pre-drilled and tapped holes - known as the Universal Mounting Spec.
It can be found here -- http://www.diyaudio.com/forums/image...ation-v2.1.pdf
Old 10th December 2012, 03:24 PM   #3244
qusp is offline qusp  Australia
qusp's Avatar
by his answer I think we can probably assume no =)
Old 10th December 2012, 03:31 PM   #3245
No means yes
Old 10th December 2012, 03:34 PM   #3246
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
The UMS drill spacing between FETs is generally @ 40mm holes, so it should fit fine according to the printout of the spec. We made care to make sure it can fit. The leads on the R100's are longer, and will fit with a little more wiggle room than the IRF240.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 10th December 2012, 03:55 PM   #3247
Thank you all for responding to the "chassis" question. Best regards.
Old 10th December 2012, 10:55 PM   #3248
OK Guys - I think I am being stupid here. I have been varying R13,R14 with fixed resistors in the range of .0125 to .1 ohms. I think I am getting a feel of what changes can happen and what I like.
Then I think about paralleling a 10 ohm pot with a .05 ohm fixed resistor and using that to tune in system. Doing the parallel resistor calculation with pot at low extreme (0 ohms) parallel combo should be zero at high extreme (10 ohms) it should be .049 ohms . Now parallel 1 ohm with .05 and you get .047. The remaining numbers (3-9 ohms) are between .047 and .049. Doesn't that say that the major variation in R13 and R14 (paralleled) is in the first few turns of a 15 to 20 turn pot and wouldn't it be better to just use fixed resistors or fixed resistors with a rotary switch ???
What am I missing?
Best
Bob
Old 10th December 2012, 11:05 PM   #3249
buzzforb's Avatar
The 10R pot is having minimal effect because of relative size. Perhaps smaller pot or just get multiple value rs and play around.
...Shape the sound , Man!
Old 10th December 2012, 11:12 PM   #3250
That's exactly what I am thinking - maybe my brain is still working
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
