Old 9th December 2012, 11:12 AM   #3221
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
Originally Posted by 6L6 View Post
Patrick's heatsinks have them side by side so a pair of J74 could be used instead of a J109, on the same pad. For good thermal tracking face to face would be the most logical in this project.
which is why I mentioned it first (but made a pretty obvious mistake), thermal tracking would be every bit as good side by side+opposed if they can use the heatsinks, also allows the current to be increased. its not like the device is anywhere near the face
they are not just designed that way so they can replace j109, but also so they can be used in sets of 4 ala SEN/CEN, which has nothing to do with j109
Old 9th December 2012, 12:04 PM   #3222
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by permaneder View Post
or that one?
that one
btw. - what's that ?
Sprint ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 9th December 2012, 12:26 PM   #3223
Originally Posted by Zen Mod View Post
that one
Sprint ?
Ja, simple operating and sufficient for my demands
Old 9th December 2012, 12:30 PM   #3224
Zen Mod's Avatar
do you mind sharing (zipped) that last one file ?
Old 9th December 2012, 12:51 PM   #3225
Of course. Send a PM and I'll mail the file plus the Gerber files
Old 9th December 2012, 01:33 PM   #3226
or that one?
lhquam, permaneder and Tea-Bag. Your PCBs are great art, organization skills and a test bed for many experiments. Will you consider the following?
  • A PCB for Unbuffered diyF6. The concerns of qusp disappear.
  • Adding a headphone output which is uncommon in Pass amps. Maybe beneficial for tweaking/balancing the important good distortion.
Best regards.
Old 9th December 2012, 01:44 PM   #3227
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Best regards.
Hi there,
Mine can be jumpered to not use the Buffering of the JFETs, source resistors for R100's or Toshiba's. In the end I will probably run without them, since my impedance is low from my electronic crossover. But for the initial testing, all parts will go in, and options guided for IRF240's or Fairchild MosFets
A headphone output is a matter of typing the outputs to a headphone jack sharing common ground. Something IMO does not belong on a PCB.
My boards are being built, so changes now are not really top of mind, unless there is a mistake and the board will not work - OR the idea is so brilliant it's worth a re-spin.
Old 9th December 2012, 02:11 PM   #3228
Originally Posted by Tea-Bag View Post
Hi there,
Thanks Tea-Bag. I look forward to bying your PCBs, and others from each artist to pursue dedicated applications.
Best regards.
Old 9th December 2012, 02:20 PM   #3229
lhquam is offline lhquam  United States
I like to make power and output connections using hexagonal standoffs attached with #4 (or M3) screws. That allows removing the boards without needing to unsolder anything. Similarly, make the spacing (and size) of the input connections so that a .1" 2-pin header can be used.
Tell me please, what would you like to tweak? I'll try to implement it.
Old 9th December 2012, 02:30 PM   #3230
The connectors on my layout are 6.3mm flat jacks. No desoldering necessary.
2.54mm pin headers are no issue. I could easily change the board, if you like.
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
