F6 Amplifier
F6 Amplifier
Old 3rd December 2012, 05:02 PM   #3181
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by Nelson Pass View Post
At the moment I do not have plans to sell those boards.
Thanks Mr. Pass. Best
Old 3rd December 2012, 05:33 PM   #3182
F6 Amplifier
Originally Posted by buzzforb View Post
Do we hav eto worry abou tproximity to toroid considering use of xformer? In my rats nest, i ha dto keep some diatance from toroid to prevent little hum. Most likely rats nest, bu tthough ti would ask. Also, i notice that Nelson shoves his all the way in the back, away from the main doughnut.
buzzforb: The last picture in the sixmoons article showed with good clarity the inside of Mr. Pass's F6. It is a goldmine of info for the DIYer. Suppose that he used an industry standard enclosure. The long side of the PCBs is along its known depth dimension. One can calculate/estimate the minimum distance between the center of the power toroid and the edges of the JENSEN closest to it for no hum. One can also calculate/estimate the center to center distance between the power JFETs for optimal heat distribution on the heat sinks.
There are 5 power resistors [ big and light grey] on each PCB. By comparison, the schematic showed only 2; and here I speculate they belong to the feedback loop. I'll gaze more at the PCBs and understand what's it mean if anything.
Old 3rd December 2012, 06:48 PM   #3183
lhquam is offline lhquam  United States
Based on their location it looks like there are two 3 watt source resistors per JFET and one 3 watt resistor for each feeback loop. I suspect that the 2 resistors in parallel per JFET are in order to tune the resistance. Papa probably has two sets of resistances on rotary switches for adjusting a channel, and then solders resistors into the board to match. Anyway, that is how I would do it for production.
Old 3rd December 2012, 07:29 PM   #3184
Here are some interesting plots based on Spice simulations with combinations of Rs1 and the Rs2, the upper and lower source resistors respectively. In all cases the F6 is driving an 8 ohm load at 1 watt. The plots are of the harmonics H2, H3 and H2/H3.
Old 3rd December 2012, 07:38 PM   #3185
F6 Amplifier
Thanks lhquam. I am still missing the 100 Ohm/5W for the feedback loop. One clearly sees the 20 Ohmer to ground. One also sees two electrolytic capacitors [of similar physical size] per JFET. Maybe two 470 uF in parallel adding up to the prescribed 1,000 uF of the schematic? The low wattage resistor between each pair of these electrolytics is the 10K resistor connected to the wiper of the 5K bias pot.
Old 3rd December 2012, 07:41 PM   #3186
Default Simulation vs Measurements
For those of you who are sceptical about the utility of Spice simulations, particularly when transformers are involved, here are two plots that show a reasonable degree of agreement between simulation and measurement.
The plots show THD, H2, H2, H2phase, and H3 phase. The upper plot is from simulation; the lower plot from actual measurement of the Teaser-6 left channel.
Old 3rd December 2012, 07:42 PM   #3187
buzzforb is offline buzzforb  United States
buzzforb's Avatar
It confirms the obivious that Nelson tunes his amplifier to ear and measurement, and not a given schematic, much like Ilquam has done with all his work . No magic, just measuring, listening, and adjusting.
...Shape the sound , Man!
Old 3rd December 2012, 07:46 PM   #3188
Rush is offline Rush  United States
Could you explain the 3rd simulation, H2/H3. The scale starts at 1% and goes off the chart?
Rush
Old 3rd December 2012, 07:52 PM   #3189
The scale is not %, but the ratio of H2 to H3. Yes, one of the plots goes off the chart - I just got overzealous in windowing the graph.
Rush
Old 4th December 2012, 04:38 AM   #3190
I measured the hum & noise on my Teaser-6 with a Fluke meter. Outputs connected to 8 ohm loads. Inputs connected to M-Audio AP-192 sound card with no signal.
left channel: 0.6mV AC RMS
right channel: 0.2mV AC RMS
As shown in post #1519 F6 Amplifier, the left channel is much closer to the toroid. However, not all the difference is due to the coupling to the Jensen transformers. I saw similar (but smaller) differences with a pair of F5 channels using the same heatsink and chassis.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright ©1999-2017 diyAudio
