F6 Amplifier
F6 Amplifier
Old 1st December 2012, 07:33 PM   #3131
flocchini is offline flocchini  United States
Update 2
First of all resistance measurements I gave in previous post were high - forgot to subtract lead resistance.
Took out the pots and R13, R14 to calibrate my ears with zero resistance on SSs
Listened for a couple hours and then did R13 =0 and R14 = .05 ohms. After that I reversed R13 and R14. To my ears with R13 =0 and R14 = .05 soundstage was forward. Reversing the resistors moved it back. When Nelson said a small amount of resistance added to SSs I think he meant it. It doesn't take much to change things.
I'm back to no degeneration - it sounds best to my ears and with the other amps in my tri-amp.The voices sound really natural - there is good slam and detail. I would love to hear F6 with a 100dB system like LaScala
Again thanks to all that have helped - may learn how to take some measurements with the Mac.
buzzforb - If no boards become available I will hand wire the Jensens.
Best
Old 1st December 2012, 07:45 PM   #3132
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
Happy you had succes...!
Yes measuring the channels to see if they have a very different distortion spectra is a good idea.
I repeat, my left channel had k3 and k2 on the same level, right channel had k2 clearly higher. Seems to depend on on the SS pairs...
and the First Wtt is......a really First Class PSS Idea
Old 1st December 2012, 07:49 PM   #3133
Thank you for everything - measurements are up next - resurrected my Waveterminal U24 and I will go from there.
Old 1st December 2012, 07:57 PM   #3134
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by flocchini View Post
Update 2
Best
Mine will be played on my ALtec system which should come in at about 98dB@1W
AS for degerneration. It is interesting to me that such a small amout of degernation could have so much affect, but I agree with you. THere is something that is truly freed in the music wthout it, but youe must really work to find the balance considering overall distortion as well. I wonder if this is a situation where reall y high quality source resistors would be in order. My question is the difference in sound a result of performance parameters chaging, ie more global feedback or does this circuit really reveal parts? Did you go without degeneration on the FE?
...Shape the sound , Man!
Old 1st December 2012, 07:57 PM   #3135
lhquam is offline lhquam  United States
I think you are missing the point. The primary source of distortion in any FET amplifier is due to the square law nonlinearity of the devices. Any feedback, whether a global loop or local source degeneration introduces higher order distortion components.
The figure below shows a mathematical derivation of the harmonic components of a single ended FET common source amplifier with degeneration. The coefficients a[i] powers of v, v^i correspond to the magnitudes of the corresponding harmonics. In a push-pull amplifier, the even harmonics tend to cancel if the device parameters and Rs are properly matches and/or adjusted. The important point of this derivation is that the odd harmonics can be reduced by minimizing Rs.
Originally Posted by Antoinel View Post
The 1978 article by Mr. Pass which is entitled "Cascode Amp design" is a must read to understand and characterize the distortion of then a power NPN bjt. In our case, cascoding locks Vds to a constant value during operation but allows for current variations.
A possible idealized output amplifying device in a theoretical diyF6 maybe an NPN-STASIS (TM). It is made up of a power NPN transistor operating in Class A driving 4 or more PNPs. One set is needed for the upper and another identical set for the lower power output positions. However, the input impedance of each NPN is low compared to that of JFET. Nonetheless, this arrangement locks the variation of the current flowing through the input NPN in charge of defining net distortion to a constant.
I can envision replacing each on the NPNs operating in constant current mode with IRFP240s doing the same in a "clone STASIS (TM)"; clearly bending backwards to accomodate the diyF6 JENSEN.
Old 1st December 2012, 08:00 PM   #3136
buzzforb's Avatar
Old 1st December 2012, 08:33 PM   #3137
No degeneration on the front end - the Idss is 8.5
I just used the 5% Stacpole Metal oxides I had here - paralleled .1 ohm resistors
jameshillj has commented on resistors in the F3 thread I believe - He used Isabellenhuette as I remember.
Old 1st December 2012, 08:52 PM   #3138
Antoinel is offline Antoinel  United States
F6 Amplifier
Thanks lhquam, you have the gift of such skills I can only wish and imagine to have. Please strike off the above clone STASIS (TM) idea with MOSFETs.
Old 1st December 2012, 10:59 PM   #3139
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F6 Amplifier
So, with Nelson's approval, I will try to post something close to the following for sale after a prototype is made and built.
It will use a daughter card concept to add in a Onetics or Jensen transformer, or allow a Perfboard to be mounted on the 2x10 2.54 Male pins to roll your own transformer onto it.
It will have all four pots and will be based on the F6 Second Harmonic. If one wants a simpler versions than jumpers need to be put in place for it. It may not be for everyone, but it will reach market, pending approval and I don't get hit with a snowplow or something.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 1st December 2012, 11:16 PM   #3140
Tea-Bag
Looks great !!!
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
