F6 Amplifier
F6 Amplifier
Old 26th November 2012, 03:29 PM   #3111
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I meant in general ratio, not 100% matching. At the very least, it would tell you the importance of having it flat across frequency. In reality, things start to become background above 8K-10k
...Shape the sound , Man!
Old 26th November 2012, 03:57 PM   #3112
lhquam is offline lhquam  United States
What I was really interested in with these curves was the variation of phase of H2 vs. frequency. Nelson has talked about having a positive (expansion) or negative (compression) phase relation between the H2 and H1, but this relationship is obviously non-constant for the F6, even over the range from 100Hz to 5000Hz, where there is about 100 degrees phase change.
Old 26th November 2012, 04:01 PM   #3113
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
Hi Ihquam,
be cautious, if you continue to analyse in such a brilliant way, will engage you in the F6, F7, F8 production.....!
and the First Wtt is......a really First Class PSS Idea
Old 26th November 2012, 07:24 PM   #3114
ra7 is offline ra7  United States
F6 Amplifier
If I had a 300B amp, I would mail it to lhquam asap. That was very interesting! Thanks.
I think the relative amplitude and phase of harmonics is what imparts a characteristic sound. You may be on to something here.
Old 26th November 2012, 11:37 PM   #3115
Antoinel is offline Antoinel  United States
F6 Amplifier
I find your choice of a triode amp for study by lhquam to be interesting. I have speculated in earlier posts that loop feedback in F6 reorganized its intrinsic OLG pentode charateristic curves to triode-like ones; by analogy with Schade Feedback in vacuum tube circuits. OLG F6 is a voltage controlled [modulated] current source which has published pentode characterisics for its output stage JFETs and also for the future diyF6 with output MOSFETs. The question which hangs or put this way: how does one prove whether CLG F6 has been transformed to a voltage controlled resistor like a triode and/or its amp?
Old 28th November 2012, 06:21 AM   #3116
kasey197 is offline kasey197
The Dastardly Dad of Three
F6 Amplifier
nelson, The distinction between the F6 op stage and almost every other quasi-comp is pretty apparent but what about f6 vs circs ?
ie what advantage(s) would you reckon between this topology and a transformer input circlotron ? (other than the need for two supplies for the latter I mean.)
Old 30th November 2012, 01:21 AM   #3117
Botte is offline Botte  United States
Botte's Avatar
Default Listening session notes
I had a nice listening session tonight and I have never heard another amplifier that reveled absolute phase better. I would go so far as to say that it becomes almost distracting. I would normally just put on something to listen to and go, now I need to test the absolute phase because it is so obvious when it is wrong when I start to listen. I also came across an album that it changes track to track, amazing. Even my SET amps don't reveal it this well. The F6 is truly a special amp.
Old 30th November 2012, 03:08 PM   #3118
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F6 Amplifier
If you can pick the absolute phase like that, you are fortunate on
several levels.
Old 30th November 2012, 07:35 PM   #3119
labjr is offline labjr  United States
Some of these claims need to be tested on mythbusters.
Old 30th November 2012, 10:24 PM   #3120
flocchini is offline flocchini  United States
Update
I degenerated the output R100s on my F6 by adding the .1ohm resistor and 10 ohm pot. I need to do more listening but for me:
With each pot turned to get min wiper to source resistance (.3 ohms) I seemed to get widest soundstage, good depth and nice attack
Keeping the Q1 pots at .3 ohms and increasing the Q2 pots so that wiper to source was 1 ohm I seemed to have the best bass and nice detail
The opposite settings was also true Q1 pots at 1 ohm and Q2 pots at .3 gave very nice bass and nice detail
Don't quite understand that but I want to do some extended listening
Question - have others used all four pots/resistors at once or may it be better to use them on Q1 with Q2 at 0 ohms (no pot/resistor) or alternately Q2 with pot and Q1 with no resistor?
Just going my ear right now - seem to be able to duplicate with just resistance measurements.
Thanks and best
Bob
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
