#3101 |
That will not work properly because the two primary windings are seeing different voltages across them and will "fight" each other. Assume that the feedback node has voltage Vfb. The voltage across the upper primary is In+ - Vfb. The voltage across the lower primary is Vfb - In-.
If In- = - In+, then clearly the voltages across the windings are different unless Vfb=0. If we believe that the total flux in the transformer is the sum of the contributions of the two primary windings, then the total flux will be proportional to (In+ - Vfb) + (Vfb - In-) = In+ - In- and the feedback has no effect. |
#3102 | |
#3103 |
The one and only
No doubt there is such, but you are likely to find that some other parameter
has been traded for it. Did you read the transcript of the BAF talk on the F6?
#3104 | |
N.B. Got the point. The Jensen in F6 is already a rarity per its writeup. Others which may push a higher OLG bandwidth will be unobtainium and prohibitively expensive. Last edited by Antoinel; 25th November 2012 at 04:58 PM. Reason: Tweak |
#3105 |
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3106 | |
#3107 |
The transformer coupling in the F6 feedback loop cause the phase of the 2nd harmonic to vary with frequency. Here are THD vs Freq and Phase vs. Freq plots for the F6 and the F5. Not how much greater the phase shift is for the F6, particularly in the mid frequencies.
I suspect that this changes the sonic signature of the amplifier. |
#3108 |
In my previous post, the F5 THD was so low that the phase change was totally determined by the MOSFET gate capacitances.
Here is the same F5 circuit with P3 adjusted for 0.025% 2nd harmonic. As you can see, the phase is essentially constant to 20kHz. |
#3109 |
Interesting thing would be to listen to both circuits adjusted for similar harmonic structure and see if they sound the same.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#3110 |
It would be hard to adjust the F5 to have 3rd harmonic high enough or
to have the H2/H3 vs frequency at all similar to the F6. What would be interesting is to see H2, H3 plots with phase for some vacuum tube amps with sonic signatures that are at all similar to the F6. |
| New F6 diy coming soon ? | Nounours18200 | Pass Labs | 37 | 31st August 2012 04:35 PM |
| Hi Vi F6 box | ioro | Multi-Way | 4 | 15th April 2012 08:27 PM |
| Whats happening with F6? | jugoslavija | Pass Labs | 1 | 1st November 2011 07:39 AM |
| Hi-Vi F6 | kkosiba | Multi-Way | 14 | 9th November 2007 08:38 AM |
| F6 | traw | Pass Labs | 7 | 2nd November 2007 07:09 PM |
