F6 Amplifier - Page 284 - diyAudio
Old 16th November 2012, 09:40 PM   #2831
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
you're begging for positive feedback ?
that way is easy to have buzzzzzz ............ and big badabooooom , if you're using sissy speakers
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th November 2012, 09:43 PM   #2832
lhquam is offline lhquam  United States
Default Common F6 schematic suggested
I suggest that we agree on a common F6 schematic, including optional parts (like Zen pots) so that we can refer to components unambiguously. The component values do not necessarily need to be shown, only the component identifiers, like R1 and P3.
The main divergence might be in the area of the bias circuits and voltage generators for the input followers.
Any opinions?
Old 16th November 2012, 09:48 PM   #2833
buzzforb's Avatar
Too easy. Have you tried no RS version. I think i remember you did.
...Shape the sound , Man!
Old 16th November 2012, 11:39 PM   #2834
Any opinions?
Can we use the official schematic as a basis for a PCB for the masses? There will alway be others that customize and diverge from the original. Perhaps a base motherboard with daughterboards for options? Too elaborate?
Dan
Old 16th November 2012, 11:48 PM   #2835
What official schematic? The only schematic from Papa since post #1 (and a later correction) is a photo of the projection screen at BAF. In any case, these schematics do not provide enough common options for DIYers to experiment with.
Dan
Old 16th November 2012, 11:58 PM   #2836
Post 2588 by Nelson Pass
Now that the cat's out of the bag via BAF, here is the official F6 schematic.
Dan
Old 16th November 2012, 11:58 PM   #2837
Zen Mod's Avatar
didn't we put enough variables already ?
perfect tutorial to everyone to make his own drek
Dan - here is da link : F6 Amplifier
and pic :
Old 17th November 2012, 03:38 AM   #2838
from generg
"I hope you will like PtP.....!
Do not forget to put an 500R or 1k pot nearby to put it parallel to the upper secondary if you should need some more k2...."
thanks generg - I will be trying it this weekend and then see if I can shorten leads, etc - I want to build on a set of Jensens to compare. I will then re-read the fine tuning info and see what I can do
Old 17th November 2012, 05:37 AM   #2839
from generg
"Do not forget to put an 500R or 1k pot nearby to put it parallel to the upper secondary if you should need some more k2...."
I went back and read the zen pot info as well as all I could find on the F5s P3
generg referring to post 2837 - am I correct in saying you are suggesting a 500 or 1k pot across pins 5 and 7 of the transformer
Bob
Old 17th November 2012, 08:40 AM   #2840
generg is offline generg  Germany
generg's Avatar
Originally Posted by flocchini View Post
from generg
Bob
yes around these values, 500R to 1000R and I recommend you to look at Ihquams experiments with this, he did all months earlier....
and really adding 8-12 db higher k2 than k3 is for me substantial to get the best out of the circuit so the pots are a must for me!
and the First Wtt is......a really First Class PSS Idea
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
