F6 Amplifier
F6 Amplifier
Old 16th November 2012, 04:03 PM   #2821
dantwomey is offline dantwomey  Canada
Originally Posted by labjr View Post
Extra pads would be fine, long as the Jensen can be mounted on the board since I imagine most will opt for the original X-former.
I would pay a small premium to help the designer lower costs. I prefer PCB over P to P.
Dan
Old 16th November 2012, 05:08 PM   #2822
lhquam is offline lhquam  United States
Originally Posted by dantwomey View Post
Anyone thinking about F6 PCBs?
Dan
Old 16th November 2012, 05:55 PM   #2823
labjr is offline labjr  United States
Needs some work. Looks a little etch-a-sketchy
Old 16th November 2012, 06:12 PM   #2824
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
F6 Amplifier
Just a bit of cosmetics...hardwork is done
Old 16th November 2012, 06:48 PM   #2825
flocchini is offline flocchini  United States
Confirming pinouts are different for the Onetics. Hopefully I can be listening before leaving for Seattle on Monday
Old 16th November 2012, 07:07 PM   #2826
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
O.K. here comes the minority report for ZM....
ISKRA has lowest THD in my measurements, a small bit lower than Jensen....
means 0,004% smaller....
because k2 is still lower than the k2 of Jensen. Buzz said this could be sign of the similarity of windings....
k3 is a bit higher than the k3 of Jensen....
so if I increase the k2 to surpass the k3 about 6db I get with the ISKRA a bit more THD than with the Jensen, that may be the reason I find the ISKRA a bit more detailed and less dry.
and the First Wtt is......a really First Class PSS Idea
Old 16th November 2012, 07:11 PM   #2827
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 16th November 2012, 09:12 PM   #2828
Here is my first PTP wiring attempt - I know needs improvement
PSU choke filter +/- 24V
Current at R100s 1.48 A
Voltage G -S on R 100s = 1.38V
DC offset approx 5 mV
Will put it in system later this evening unless I hear not to
Thanks everybody
Old 16th November 2012, 09:22 PM   #2829
generg's Avatar
F6 Amplifier
I hope you will like PtP.....!
Do not forget to put an 500R or 1k pot nearby to put it parallel to the upper secondary if you should need some more k2....
May I all ask again....?
The original circuit Nelson gave us had in my build k3 and k2 on the same level,
is this intended or due to my build and parts?
Shouldn't k2 be dominant per se? My second channel even had k3 higher than k2.
Old 16th November 2012, 09:29 PM   #2830
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I am sure it is similar to the J2, in that all the parametrs matter. Isnt ig the easiest amp to play around with. Have you tried switching the phase of yhe top and bottom secondaries?
...Shape the sound , Man!
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
