F6 Amplifier
F6 Amplifier
Old 14th November 2012, 01:22 PM   #2761
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
Originally Posted by Tea-Bag View Post
Generg,
Is the sounds growing on you?
sorry Tea-Bag, this is is a situation where my English is not sufficient...
what do you mean...?
and the First Wtt is......a really First Class PSS Idea
Old 14th November 2012, 01:24 PM   #2762
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F6 Amplifier
do you like the F6 with Jensen better than before? Has the sound improved?
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 14th November 2012, 01:30 PM   #2763
generg's Avatar
F6 Amplifier
coming from ultra resolution of J2, it was another sound I had to get customer to....
Botte is right the medium area with the Jensen is similar to the F3 sound with a bit better bottom.
"For reasons unknown" I like the Edcor as an available xformer a bit more....
but it is really a matter of taste... Even I could change all day long and enjoy both sounds...
Old 14th November 2012, 01:46 PM   #2764
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
Originally Posted by generg View Post
NOT to speak of the green ones, some well known Greenhorn uses every day in myrads ....impossible!
yup
real men use green 3mm LEDs
everything else is for sissies
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th November 2012, 01:47 PM   #2765
nicoch58 is offline nicoch58  Europe
Old 14th November 2012, 06:37 PM   #2766
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F6 Amplifier
Originally Posted by Botte View Post
I have my F6 running. The sound is between the F3 and the F5, leaning towards the F3 in the upper registers and the F5 in the bottom end.
I take that as a high compliment.
Old 14th November 2012, 07:19 PM   #2767
Zen Mod's Avatar
F6 Amplifier
Old 14th November 2012, 07:30 PM   #2768
generg's Avatar
F6 Amplifier
in this case 3 + 5 = 6
Old 14th November 2012, 08:46 PM   #2769
Antoinel is offline Antoinel  United States
F6 Amplifier
Default Interest in a phase inverting diy F6?
If yes, a theoretical schematic is attached. The following modifications are principally the re-wiring of the parent.
  • The parent output node is now Ground
  • The output node is now the parent Star Ground
  • Each channel in a stereo enclosure must have its independent power supply.
  • The phase notations of the Jensen's primary windings are reversed.
Will it work? Detriment or value?
Brgds
Old 14th November 2012, 10:04 PM   #2770
lhquam is offline lhquam  United States
With transformer coupling there is no reason that you cannot float the power supplies, assuming that the feedback is correctly phased and at the correct level.
OTOH, if you are going to float the power supplies why not implement a circlotron? You can even dispense with coupling transformers if you follow the path chosen by Rothacher The Amazing Fet Circlotron by Mike Rothacher.
Brgds
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
