#2741 |
dunno - ask Pa for that
he's changing that page all the time ........
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#2742 | |
Brgds. |
#2743 | |
I have also used a non-inverting TCA as a working amp with a simultaneous correction for phase at the primary of the transformer to be like the posted schematic of F6. It worked as well as the phase inverting amp above. The question is not will it work; but rather how will this modified diy F6 sound with your loudspeakers? Clearly you have the flexibility to lower or increase Vf [in my schematic]. Last edited by Antoinel; 11th November 2012 at 07:44 PM. Reason: tweak |
#2744 |
I need to add one detail about the Full Range drivers which I used in my study. This low cost driver [~$100] is a 15 inch Aluminum Cone Musical Instrument Speaker [40 Hz -7 KHz]. It is un-enclosed, and is securely bolted to a ceiling joist. Call it if you wish a No-Baffle situation. Both R and L drivers are angled inward, and focus their output at the listening sweet spot on the floor.
I can only imagine the sound with other [pricier] FR drivers like Fostex, Lowther and others. |
#2745 |
ZM
Sic58
#2746 | |
The one and only
#2747 |
masterful forgery ZM... as my kids would say - cheeky monkey!
#2748 |
I have my F6 running. The sound is between the F3 and the F5, leaning towards the F3 in the upper registers and the F5 in the bottom end.
I had to use two red LED's to get enough bias for the SemiSouth R100's. I'm also running my rails at 30 volts so I added a 1.2K in the drain of the front end FETs to burn off a few volts. I have it in my Aleph, F5, now F6 Chassis and the power supply has remained the same. I did add an additional RC on the board with a 22KuF and .22 ohms just to be able to check the bias without raising the hood on the rest of the supply. ![]()
#2749 |
The Dastardly Dad of Three
Nice !! Neat idea on the rc for bias measurement....
#2750 |
| New F6 diy coming soon ? | Nounours18200 | Pass Labs | 37 | 31st August 2012 04:35 PM |
| Hi Vi F6 box | ioro | Multi-Way | 4 | 15th April 2012 08:27 PM |
| Whats happening with F6? | jugoslavija | Pass Labs | 1 | 1st November 2011 07:39 AM |
| Hi-Vi F6 | kkosiba | Multi-Way | 14 | 9th November 2007 08:38 AM |
| F6 | traw | Pass Labs | 7 | 2nd November 2007 07:09 PM |
