F6 Amplifier
F6 Amplifier
Old 2nd November 2012, 09:07 PM   #2601
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
wakooAlNiCoyank
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd November 2012, 09:11 PM   #2602
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Not going to fail due to lack of options.
THese have those cool clear phragms
...Shape the sound , Man!
Old 2nd November 2012, 09:17 PM   #2603
Zen Mod's Avatar
F6 Amplifier
I can't see what you wrote
you're on my ignore list , few days already
Old 2nd November 2012, 09:55 PM   #2604
Antoinel is offline Antoinel  United States
F6 Amplifier
Thank you Mr. Pass for the schematic. Both F6 [B; transient name if I may], and notably F6 [UB; transient name; you buffer it from our {we} perspective] are continuing examples of the Pass Discipline for creating the simplest, most effective, and most elegant designs.
F6UB [if I may give it this transient nomenclature] appears to have a gain of 15 dB and the performance attributes of F6B. Most interesting is that error correction happens in the primary winding of its transformer. We now have a universal, new and improved Classic.
Old 2nd November 2012, 10:17 PM   #2605
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Zen Mod View Post
baaad Pa .......
Would you rather prefer him to build 10 for the out-house ?
(for some reason, I almost feel proud for still having experienced those in my early years)
Old 2nd November 2012, 10:41 PM   #2606
dsdjoy is offline dsdjoy  Germany
Originally Posted by Nelson Pass View Post
Now that the cat's out of the bag via BAF, here is the official F6 schematic.
Thanks !
However, I know from DIY attempts of cloning J2 (I have the original here), that schematics and same parts isn't enough to reproduce the sound of the original. My J2-clone with same schematics and same parts sounded very noticeably different from the original.
I learned from that, that it's very important to select transistor values and/or adjust resistors to get into the sweet spot. It is also important to have possibility to measure THD and 2nd/3rd harmonic - to see where one is going when modifying values.
As a consequence, any F6 clone build only according to schematics can sound different from another F6 attempt, unless Nelson gives us advice on how to fine-tune it. Or you fine-tune it to your personal liking....
I hope and wish that Nelson will give us some advice on how to get at least a bit close, on how to select transistors and what THD%-value and 2nd/3rd harmonic-% we should be designing and building for ?
Old 2nd November 2012, 11:44 PM   #2607
flocchini is offline flocchini  United States
Hopefully I understand the F6 schematic ( thanks Nelson ) well enough to ask the following question but there are no guarantees. When P2 is adjusted to give the 1.2V bias what is the corresponding current draw?
I am asking because I have transformers that are just asking for a choke filter. To get the minimum inductor size for the power supply I need the expected current and voltage. Minimum inductance = .9 x (Voltage/ current)
Bob
Old 3rd November 2012, 12:15 AM   #2608
buzzforb's Avatar
You could put a .1R 3W in temporarily to measure current settting, then remove after you are done. Degeneration will not be significant enough to cause a major change when removed. Can adjust low to be safe.
Old 3rd November 2012, 01:03 AM   #2609
flg is offline flg  United States
flg's Avatar
You could put it in the drain of the top xister with probably no effect at all
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 3rd November 2012, 01:05 AM   #2610
Zen Mod's Avatar
F6 Amplifier
let's just say that Iq was in 1A55 ballpark
somewhere earlier I gave little table of SJEP tempco at 2A (or something like that ) , so I'm expecting that , on value what I think I heard in Pa's Lecture , it's spot on dead ..... or dead spot on
so , let's Iq be a pulsar , not ookin' Ugs
btw. guys - flocchini didn't asked for Iq measuring procedure , but for expected Iq , for PSU calculus purposes
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
