F6 Amplifier
F6 Amplifier
Old 16th October 2012, 03:32 PM   #2411
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by lhquam View Post
The SIT makes most sense in a non global-feedback design. I suspect that the F6 would not have the sound Pa was looking for with zero feedback.
lhquam: What is the probability that a bright Software Engineer can devise a DSP to imbibe any line-level audio signal with triode, SIT, H2 and H3 , Pass amp, etc characteristics? Why continue to depend on future power amps to achieve these properties which at times appear vague?
Old 16th October 2012, 04:10 PM   #2412
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
naah ......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th October 2012, 04:15 PM   #2413
dsdjoy is offline dsdjoy  Germany
In post #2249 F6 Amplifier
For some reason, one channel is behaving as predicted by Spice, but the other channel is not behaving well. I have to carefully check the wiring and components. The R100s were fairly well matched, so I do not think their differences could explain the different THD spectra.
I am having the same issue with one channel of a (Mu Follower) amp with matched Semisouth R100.
In one channel I can adjust H2 vs. H3 to desired level by varying source resistors.
The other channel is totally off, also having high H4 distortion.
Could it be an issue with Gate Leakage of R100, as described by Nelson for the R085 in the 'SiC Puppy SE Amp" thread ?
Old 16th October 2012, 04:17 PM   #2414
F6 Amplifier
Originally Posted by Zen Mod View Post
naah ......
Did you see Fearless Felix drop 24 miles out of the sky? Incredible! Said who it could not be done? Where's Joachim Gerhardt to weigh in?
Old 16th October 2012, 04:19 PM   #2415
Zen Mod's Avatar
F6 Amplifier
it can be , but it never will sound as KISS
Old 16th October 2012, 04:31 PM   #2416
F6 Amplifier
I agree. KISS will be the industry standard against which these potential DSPs will look up to.
Old 16th October 2012, 04:33 PM   #2417
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F6 Amplifier
It would seem logical but somehow the efforts in that direction have not
borne fruit. Similarly, simply introducing these elements on the front end
of the amplifier while using a highly linear output stage have not given the
same results.
Old 16th October 2012, 04:41 PM   #2418
lhquam is offline lhquam  United States
Apparently gm matching of the R100s isn't enough. In my case, I was able to obtain the desired results by swapping in a spare R100 and adjusting the Zen pots (effectively the source resistors). I haven't carefully checked the gm (or other) parameters of the R100s that are now in use.
Old 16th October 2012, 04:43 PM   #2419
Could it be that factors like output impedance and other load dependent behaviour haven't been addressed by those attempts?
same results.
Old 16th October 2012, 06:14 PM   #2420
F6 Amplifier
same results.
I envision a multi-disciplinary team including gurus like you of high-end audio [a key contributor] revisiting and laying the framework for a solution to this question. Matter of time!
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
