F6 Amplifier
F6 Amplifier
Old 14th October 2012, 12:09 AM   #2351
lhquam is offline lhquam  United States
I am not sure what kind of speakers to consider. I chose the CDM1s because of room constraints. The room is very asymmetric wrt. the stereo centerline and placement 3 or more feet from the walls would be quite difficult. When I build this house, I didn't spend enough time to consider room acoustics.
In the photo you might note that the wall behind the speakers is 2 inch thick acoustical cotton, which solved an extreme flutter echo problem due all of the windows and ceramic tile on the floor. Acoustic treatment of the wall behind the speakers rather than the opposite wall is the reverse of what some experts recommend, but it seems to work well.
Originally Posted by buzzforb View Post
Time for speaks
Old 14th October 2012, 12:16 AM   #2352
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
beautiful an cozy space
but those pipies are not worthy of F6
what you need is saw , to cut those most left and right parts of that awesome piece of furniture , and to place something with at least 12" of cone ; fast and clean
then you'll have speaks belonging to 25W A class story
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th October 2012, 12:22 AM   #2353
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Throw out two couches, hang giant tapestry in hole containing speaks, add speaks of choice. Got window isdues to deal with. Gonna load right side more than left due to wall proximity. Like the layout, ceiling is good, but rest it is murder for setup. I would venture that nearfield lsitening is best bet to reduceroom inferaction. Good news is, you haven theard amps or speaks yetI have nice FR moniters and will be building OB and horyns shortly. Now convincing wife to rearrange entire liyving room to accomomadate system. Thats why i stopped with amp expkoartion. Gotta start makin gthings pretty. You have a lovelt home, BTW. Other swill have better advice, i am sure
...Shape the sound , Man!
Old 14th October 2012, 12:24 AM   #2354
buzzforb's Avatar
Love the glass of vino. Major part o fmusical enjoyment
Old 14th October 2012, 01:00 AM   #2355
Yup, it wasn't visible in the first shot (not shown), but I moved the glass and took another shot just for you to envy.
Any suggestions on speakers that might work?
Old 14th October 2012, 01:23 AM   #2356
buzzforb's Avatar
In my previous audio life, i heard the lijes of linn, totem, magnepan, and so on. When i got started in this diy thing, i built an AJ and some Alpair 10.2 floorstanders. They both rocked my world. I just achieved 85-90% of the quality of previous systemds for a meager fee. I then launched into amps, as they had lower initial investment. I now know that my speaks are my weak point. Not that they are bad. They are wonderful, but i want to go the route of high efficiency systems to better utililze the FW series amps. I will be building a OB using AN 15 and also a horn/woofer combo. This will be added to my FR/ woofer system and then i have good rep of all types. I am really exvited about both horn and OB. Both will be new. Both will be in the sweet spot of FW amps having efficiency of 95+dB. Look up SEOS 12 horn with b&c250 and beyma 12br100. This could be a potentially sick sounding pro style monitor that would probably suit your listening space well. You can get plastic vetsion of the horn for $25. Diysoundgroup has a denovo 360 that is suppoosedly similar, if not better than, the bc250, and is only $75 per driver. Add thr 12" beyma for $150 each, and you have only dropped $500-600 for a really nice setup. ZM will have better ideas for big circle style speaks. You want Sd and efficiency.
Old 14th October 2012, 01:43 AM   #2357
I find that the room is alive enough that 1 watt is plenty of power for most listening. Thus, speaker efficiency is not a major factor.
In my previous audio life, i heard the lijes of linn, totem, magnepan, and so on. ... You want Sd and efficiency.
Old 14th October 2012, 01:51 AM   #2358
buzzforb's Avatar
I cant argue that from a technical perspective, but i think you might be surprised. Also would suggest greater dynamic range is another benefit of suggested options. Big rich musak!
Old 14th October 2012, 01:53 AM   #2359
Zen Mod's Avatar
F6 Amplifier
regarding bass drivers , I'm really not having right info for your side of Big Splash , guys ;
that Beyma is having too much of moving mass and Le , for my liking
what you need for proper Econovawe is more old-scoolish bass driver
edit:
lhquam ;
think sensitivity , not efficiency
Old 14th October 2012, 01:56 AM   #2360
buzzforb's Avatar
Something along Altec lines, i assume. Didnt suggest it because of big money.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
