F6 Amplifier - Page 226 - diyAudio
Old 5th October 2012, 07:24 AM   #2251
buzzforb's Avatar
Increasing the Rs size definitely cleaned things up, but it sounded compressed, without any soundstage. Sweet spot is elusive
...Shape the sound , Man!
Old 5th October 2012, 08:43 AM   #2252
bobodioulasso's Avatar
Originally Posted by lhquam View Post
I am referring to AC voltage between the winding and ground (or other windings) not the AC voltage across the winding.
By Gain, I am referring to the closed-loop gain of the amplifier. Actually, the ratio of Vout to the voltage into the top of the driven primary winding.
Thx for precision.
Old 5th October 2012, 10:36 AM   #2253
triode_al's Avatar
Originally Posted by generg View Post
.....the problem could be that two perfect matched halves produce mostly k3 and no k2 and a slight mismatch will care for the k2 part. Of course absolute distortion is growing in this way, but the SemiSouth have so much less distortion compared to the IRF that you can risk some more k2 distortion to tailor the sound!
you must only find a way to get the offset of about 200mV back to zero but keep the distortion spectra.... or take a cap!
This could also be achieved by adding a small extra parallel [variable] current source that imbalances the balanced outputs to get just the trifle of H2 you like.
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 5th October 2012, 10:39 AM   #2254
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
#2074 :
Originally Posted by Zen Mod View Post
why offset , when you can add SE bias?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th October 2012, 04:58 PM   #2255
buzzforb's Avatar
Is running primary in series a dumb idea?
Old 5th October 2012, 05:02 PM   #2256
lhquam is offline lhquam  United States
It reduces open-loop gain by a factor of 2 and changes the transformer impedances by a factor of 4. I cannot see any advantage for doing it.
Old 5th October 2012, 06:16 PM   #2257
After switching back to my F5 balanced with minimal THD, I am less happy with it now. High frequencies are too too sharp.
By first F5 build had badly mismatched FETs. But there was a satisfying sweetness to its sound that I have not been able to replicate. At that time I did not have equipment to measure the harmonics, so I do not know what the harmonic mix might have been. So far, my tweaking of the Teaser-6 does not come anywhere near to that sound.
lhquam: A method to tackle what you are doing is to start with an amp which already has an accredited sweet spot and then deny it [and yourself]; but of course reversibly, and at will. For example; you seem happy with your F5. I gather [implicitely] from your reports that it operates at its sweet spot. So here is a proposed approach to unravel the role of the Jensen transformer and loop feedback as potential variables affecting the sweet spot.
The attached file ModF5.pdf shows a proposed modification of the F5 schematic which I copied from the attendant article by Mr. Pass. It is not F5; but a tool to study the suspect variables above. I cut the pristine schematic of F5 at selected spots by using a razor blade. I then inserted the Jensen transformer plus other passive components, and finally spliced everything back together. It may need further tweaking; but I hope that my surgery was least intrusive so as to "preserve' the parent sweet spot. The mod circuit has a Zen Pot [P3; is it the sweet spot generator?], and the bias of the output stage is essentially unperturbed. I am not sure about the components in the NFB path; but they can be adjusted to suit.
The schematics [ConceptualF6#0,1,2.pdf] which I proposed in an earlier post several days ago can also be used as tools to study the effects of above suspect variables. The parent Zen amps are already accredited with "sweet spot" musicality.
Old 5th October 2012, 06:39 PM   #2258
Default Proposed alternate biasing scheme for Conceptual F6
Dear DIYers. The subject is attached. I borrowed the thought process to write it from the schematic of F5. May have DC servo-action; not that your current designs [Teaser-6, Franken6 etc.] need auto offest control.
Old 5th October 2012, 09:32 PM   #2259
The one and only
Nelson Pass's Avatar
I am not sure that the ratio of H2 to H3 can be held constant across frequency with H2>H3.
You also will have difficulty trying to keep the ratio constant with different
amplitudes. Probably best to select for your listening level.
Old 5th October 2012, 09:50 PM   #2260
Ejam is offline Ejam  Australia
Default End the Agony
Nelson
How about ending our collective misery and releasing the F6 article, please. 2000 plus replies is surely enough agony.
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
