Old 4th October 2012, 07:18 PM   #2241
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
shoot
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 4th October 2012, 07:32 PM   #2242
buzzforb's Avatar
All ears!
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 4th October 2012, 07:40 PM   #2243
bobodioulasso's Avatar
Originally Posted by lhquam View Post
The sweet spot?
On your schematic L3 has one end open circuit.
Old 4th October 2012, 08:52 PM   #2244
lhquam is online now lhquam  United States
Here it goes...
In post #88 Papa says: "One of the charms about the transformer vs JLH/PLH phase splitter is that it delivers pure symmetry in the same way a circlotron does - each like polarity part is subjected to the same conditions, although in opposite phase..."
In order to achieve "pure symmetry" the effects of the parasitic currents due to the transformer windings to have must have a symmetric effect on the two output FETs.
There are numerous formulations for the optimal modulation voltage for the "spare" winding: an approximation that assumes the open-loop gain (OLG) is very high and more exact formulas that takes OLG into account. I present here the simpler approximation.
Assumptions:
  • The interwinding capacitance is C and is the same between any 2 windings.
  • Winding 1: The driven primary winding has an AC voltage of Vin.
  • Winding 2: The "spare" primary winding has AC voltage X.
  • Winding 3: The upper secondary winding has an AC voltage of Vout=Gain*Vin.
  • Winding 4: The lower secondary winding has an AC voltage of 0.
The AC current I[j,k] between winding j and winding k is 2*PI*f*C*(Vj-Vk), where Vj and Vk are the AC voltages of windings j and k.
Thus the AC current into the upper winding 3 is the sum of the currents from other other 3 windings which is Itotal[3] = I[3,1]+I[3,2]+I[3,4]
The AC current into the lower winding 4 is Itotal[4] = I[4,1]+I[4,2]+I[4,3]
The AC currents have a symmetric effect on the output FETs when Itotal[4] = -Itotal[3]
0 = Itotal[3] + Itotal[4] = I[3,1]+I[3,2]+I[3,4] + I[4,1]+I[4,2]+I[4,3]
= I[3,1]+I[3,2] + I[4,1]+I[4,2]
= 2*PI*f*C*(V[3]-V[1] + V[3]-X + V[4]-V[1] + V[4]-X)
= 2*PI*f*C*(2*Gain*Vin-2*Vin - 2*X + 2*0)
= 4*PI*f*C*(Gain*Vin-Vin-X)
X = (Gain-1)*Vin
Old 4th October 2012, 09:17 PM   #2245
Zen Mod's Avatar
have no objection
there is still one dilemma which you probably need to solve - is it that , evidently measurable progress , beneficiary to sound ?
what I grasp till now from Pa's writings , it's desirable to have K2 above K3 (and greater), but their ratio is still Golden one ......
considering that I believe in his ear/brain combo more than to mine ( if nothing else , mileage is greater ) , I also believe that we all are waiting to see his choice regarding that ....
great work ,lhquam
Old 4th October 2012, 10:41 PM   #2246
I am not sure that the ratio of H2 to H3 can be held constant across frequency with H2>H3. It is certainly possible to hold THD nearly constant ans shown in post #2237.
Originally Posted by Zen Mod View Post
have no objection
great work ,lhquam
Old 4th October 2012, 11:16 PM   #2247
Ihquam,
i can follow your calc but do not understand your statements 3 and 4
Having four identical windings, i thought each were showing same AC voltage.
What "Gain" exactly define?
Old 4th October 2012, 11:21 PM   #2248
I am referring to AC voltage between the winding and ground (or other windings) not the AC voltage across the winding.
By Gain, I am referring to the closed-loop gain of the amplifier. Actually, the ratio of Vout to the voltage into the top of the driven primary winding.
Originally Posted by bobodioulasso View Post
Ihquam,
Old 5th October 2012, 02:25 AM   #2249
I have been listening to the flat 0.1% THD version with Gain=5, Rs=0R12.
I am not happy with it.
Not having 4 instrumented pots I have not done serious listening at THD levels other that 0.1%. I find that I cannot maintain a flat THD vs. Frequency spectrum without adjusting both P3 and P4, the upper and lower Zen pots.
Since Papa (and others) have been suggesting THD (particularly H2) up to 0.1%, I will shift away from high open-loop gain and feedback to more degeneration and possibly higher gain to reduce feedback. My next experiment will be with 0R47 source resistors.
Originally Posted by buzzforb View Post
Which do you like best?
Old 5th October 2012, 04:37 AM   #2250
After switching back to my F5 balanced with minimal THD, I am less happy with it now. High frequencies are too too sharp.
By first F5 build had badly mismatched FETs. But there was a satisfying sweetness to its sound that I have not been able to replicate. At that time I did not have equipment to measure the harmonics, so I do not know what the harmonic mix might have been. So far, my tweaking of the Teaser-6 does not come anywhere near to that sound.
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright ©1999-2013 diyAudio
