F6 Amplifier
F6 Amplifier
Old 3rd October 2012, 01:52 PM   #2211
kasey197 is offline kasey197
The Dastardly Dad of Three
F6 Amplifier
If the parasitic capacitance is a major issue as you suspect, then you could use two separate transformers for the two halves to prove the point either way, esp as you have two of the jensens already... Just my 2 cents ...
Old 3rd October 2012, 02:20 PM   #2212
lhquam is offline lhquam  United States
If two transformers are used in the way shown in the F6 Conceptual Schematic, there is still a problem. The AC voltages between the secondaries and the primaries are different. The top trafo has (Gain-1)*Vin AC voltage. The bottom trafo was -Vin AC voltage. If the Gain is chosen to be one, then the interwinding currents will cancel, otherwise they will not.
Old 3rd October 2012, 05:17 PM   #2213
The sweet spot?
If the "spare" transformer winding is connected to a resistor divider generating (approx) Vout*(Gain-1)/Gain as shown in the schematic below, the interwinding parasitic currents are nulled.
I used a potentiometer to adjust the resistor divider ratio and generated the following harmonic distortion sweeps with slightly different adjustments of the Zen amount pot.
If you want to add more 2nd harmonic, use the Zen amount pot to increase it.
Old 3rd October 2012, 05:42 PM   #2214
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
I like that mid pic
regarding parasitic cap. of winding - moi thinks that we are splitting da hair
can you hear difference ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd October 2012, 06:44 PM   #2215
BudP is offline BudP  United States
BudP's Avatar
F6 Amplifier
Zen, consider the 3.5k to 90k multiplication factor provided by the core, to any irregularity in the B Field transform from antenna to antenna up through 3.5 kHz. Then consider that it is physically impossible to wind quadfiller and keep all wires where they should lay. You can get a bifillar winding to couple perfectly, or very nearly so. You cannot say the same for four wires, wound into a narrow winding well, guided by either delicate fingers or uncontrollable mechanical traverse. The graphs shown will sound different, if for no other reason than where the differences are in the FR.
Contemplate the differences heard between two drivers, one with an uncorrected initial 4 ms response and one with a 4 ms response corrected with manic spots.
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 3rd October 2012, 06:59 PM   #2216
In post #2213 I forgot to mention that the graphs were NOT from simulations, but actual measurements.
Old 3rd October 2012, 08:22 PM   #2217
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
I can confirm by experiment today that the Zen Pot is a fine way to trim distortion level and spectra even in the case of feedback with Mufollowers like SIT2 (NFB) and J2 (FB)
the link again... L'Amp: A simple SIT Amp
and the First Wtt is......a really First Class PSS Idea
Old 3rd October 2012, 08:45 PM   #2218
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F6 Amplifier
You are overlooking another location for trimming the cancellation, which is
resistance across the secondary coils. Typical values would be on the order
of 200 ohms or more.
Old 3rd October 2012, 09:02 PM   #2219
generg's Avatar
F6 Amplifier
Mostly I have no overlook.... especially in the case of F6.
Still fixed on J2 and Mikes SIT amp I confess.
Thanks for the hint......
Old 3rd October 2012, 10:14 PM   #2220
I briefly experimented with that in the early days of my Teaser-6 build, but other parameters were too far from the "sweet spot" at the time to detect an improvement. I will experiment with it again.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
