F6 Amplifier
F6 Amplifier
Old 2nd October 2012, 04:14 PM   #2201
lhquam is online now lhquam  United States
Here is a simulation of my latest circuit tweaks shown in the attached schematic. The purpose of these tweaks is to see how low I can get the 2nd harmonics and THD.
The primary changes are to allow one on the primary windings to freely float, the careful choice of the Rswip values to balance the AC currents through the source resistors, and the careful choice of C3 to null the 2nd harmonic at high frequencies.
Old 2nd October 2012, 04:26 PM   #2202
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
why trying all the time to have K2 below K3 and K>3 ?
your ears will start bleeding
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd October 2012, 04:30 PM   #2203
The objective is to understand the role of the circuit parameters in determining the 2nd harmonic, not the configuration for best listening.
BTW: In the sweep, the sum of the harmonics greater than H3 is lower than H2.
Old 2nd October 2012, 04:35 PM   #2204
Zen Mod's Avatar
F6 Amplifier
agree for understanding
anyway - try to adjust to have K2 above K3 , then listen
btw - in sim , maybe is better to have one secondary flippin' in the breeze , but I think that better inter-coil coupling with both prim. connected , will give better results in vivo
Old 2nd October 2012, 05:34 PM   #2205
With the winding floating, its AC voltage will be Vin*(Gain+1)/3 (ignoring all other circuit capacitances). If Gain=2, then the winding will float at the same AC voltage as the other primary winding.
Old 2nd October 2012, 05:44 PM   #2206
Zen Mod's Avatar
F6 Amplifier
I was thinking of better/tighter magnetic coupling between P and S
it is always better when you have P:S:P:S , than S:P:S
for my logic , better signal transfer will result in greater verity , even taking in account increased capacitive losses
I spent some time playing with MM and MC heads feeding various xformers , amongst others even repeaters (my lucida intervala ) , so those are my conclusions
anyway - check those sims with ears , and use whatever suits you more
Old 2nd October 2012, 07:09 PM   #2207
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Ilquam, his old sig was Choky
...Shape the sound , Man!
Old 3rd October 2012, 03:36 AM   #2208
Regarding sims (and nuclear arms treaties): Trust But Verify!
My objective is to understand how to get the best measured performance, and then add back harmonics in a controlled fashion. If I can null the H2 effects of the transformer interwinding capacitances, then I can controllably add H2 back with the Zen Pot.
Old 3rd October 2012, 05:21 AM   #2209
BudP is offline BudP  United States
BudP's Avatar
F6 Amplifier
A P,S/S, P winding format, with an increase in wire size by one AWG diameter in the outer P, to help balance DCR and with the secondaries wound bifillar should eliminate all of these considerations. The two secondaries will be tightly coupled to each other, but this should be an improvement in distortion characteristics.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 3rd October 2012, 05:28 AM   #2210
I am working with the Jensen JT-123-FTPCH transformer which is quadfillar. I am assuming (possibly incorrectly) that the windings are identical and have equal couplings to each other.
Bud
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
