F6 Amplifier - Page 220 - diyAudio
Old 2nd October 2012, 12:08 AM   #2191
lhquam is offline lhquam  United States
Here is F6 Conceptual Option 5. This might nearly double the open-loop gain.
Originally Posted by buzzforb View Post
EWE! I forgot about number two.
Never mind. I am going for uber low distortion, then magic SE trick. All will have to wait for completion of M2 bastardo. Nothing like a good fight.
Old 2nd October 2012, 12:10 AM   #2192
buzzforb's Avatar
Clever Ilquam. Toldyou this was tweakers amp.
...Shape the sound , Man!
Old 2nd October 2012, 12:19 AM   #2193
I suppose I should cut a bunch of traces on my PCB and give it a try. But I am still tweaking my "original" Teaser-6.
Old 2nd October 2012, 12:43 AM   #2194
buzzforb's Avatar
No sense of adventure
Mine is torn down and off heatsink. Will build back and compare with few changes. Are you sure that interwinding C is cause of assymetry?
Old 2nd October 2012, 01:56 AM   #2195
Using screws into standoffs for power and output connections and a PCB header for the input connector, I can completely tear down, modify, and reconnect in about 4 minutes plus the modification time. No soldering required, except for the PCB mods, of course.
Old 2nd October 2012, 01:58 AM   #2196
I have new and novel idea to attack the interwinding capacitance issue. I should be able to report in a day or so.
Stay tuned to this channel!
Old 2nd October 2012, 01:59 AM   #2197
buzzforb's Avatar
Sounds nicely done. Still not liking it as much as F5? Have you fiddled with p3 on f5 or have measurements to compare the two?
Old 2nd October 2012, 02:06 AM   #2198
I have not twiddled much with P3 on the F5 because the pots are not instrumented (ie. no readout) for repeatable evaluations. I have added 10-turn pots and dials to my F6 Zen pots to do more listening experiments.
Old 2nd October 2012, 06:35 AM   #2199
bobodioulasso's Avatar
Originally Posted by Zen Mod View Post
...some of possible variations are already shown here :
F6 Amplifier
but , without severe limitation of upper Jfet's modulation , you can hardly have any decent output ; and even then , efficiency of amplifier will be simply awful ; depending of said modulation limitation/attenuation , you'll have anything between total silencer and simple CCS loaded amp...:
Don't take it bad, Zen Mod, though you might be a little bit responsible of Antoinel barking up the wrong tree cause in phase driving should'nt seriously be contemplated like in the post you point at.
Old 2nd October 2012, 07:28 AM   #2200
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
that was my hysteric attempt to make sense from Pa's repeatedly confirmed but still incorrect schmts
catch is in fact that I'm/we are often thinking too much about hidden agenda behind his decisions , putting unnecessary burden on his shoulders
there is no reason that he must be serious and uber-responsible all the time ......
conclusion - there is nothing wrong with good olde quasi push-pull ....
http://youtu.be/VXjb0aI57tQ
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
