F6 Amplifier
Official Court Jester
Joined 2003
curiosity killed the cat - repeaters quality
just tested ( to refresh my weak memory) those repeater coils (pictured in one of my previous post)
exacttype is Iskra TL-1M , so called 600:600 , in fact 4 x 150R
two primaries connected in parallel , fed with siggene , 50 ohms tap
CRO across one secondary , loaded with 6K8 (estimated range of load in F6 )
it's 'ookin' linear 15Hz-58Khz , and up to 280Khz ;
there is some rise in few freqs between 58KHz and 180KHz , but nothing what appropriate RC loading can't handle
and they're primary made for telephone range :clown:
but do not forget some other wakoo implementations of telephone transmission lines - teleprinters and other crazy military purposes
I don't know did Pa chose lowish source resistor , or highish
let's wait to see what he chose - greater linearity or lower Rout
While we wait, we may analyze the schematic of simplified F6. Its front end is a complementary common drain configuration. Thus, it does not have voltage gain; but current gain. Is it correct to assume that the interstage transformer has a step-up voltage gain of 2? The output stage appears to have a voltage gain of 1. So the net open loop gain of the simplified F6 equals 2 or 6 dB [at best; from the transformer].
Joined 2003
pretty much wrong , generally
input is Jfet voltage buffer
xformer is 1:1+1 (+ sign irrelevant for gain calc - take it as 1:1)
you can take output stage for calculations as sort of cascoded/double SE , so making gain calc as simple SE , then go from that (multiply with 2)
gain is simple - Rload/(1/S +Rs)
for more of same simple but effective logic - look at Pa's post here : http://www.diyaudio.com/forums/pass-labs/215729-help-f5-gamut-style-mosfets-5.html#post3107663
you can take output stage for calculations as cascoded SE , so making gain calc as simple SE , then go from that
The calculation works for F5 because it has an output stage with opposed MOSFET drains. When the upper section is more on, the bottom section is relatively more off [high load impedance] and vice versa. In the simplified F6, the upper output FET is operating in the common drain configuration. We have learned the fundamental propertry of a source follower [upper FET] that it has voltage gain of 1! I will be surprised if you dispute this regardless of the math expressions you put forth. So the bottom FET must also generate a voltage gain of 1 to preserve the symmetry of the output signal.
Consider for a moment that there is no top winding on the top FET. It is only a CCS, floating above a common Source gain stage. O.K.?
Now add the top winding... A small amount of signal, floating above the gain stage will be summed with the CCS. When the signal goes positive in the bottom secondary, the bottom FET turns on, higher current flows, the output swings low slightly more gain happens due to higher current! At the same time the signal is going negative in the top FET resisting the bottom FET slightly (reducing gain slightly).
When the signal in the bottom FET swings negative, the FET turns off and swings the output high. Somewhat less gain happens due to lower current. the top FET swings slightly higher due to some added signal from the top secondary, making up for the bottom FETs reduced gain????
Can anyone follow that???
Thank you for your explanation. Mr. Pass and/or ZM will reduce your language above [and mine below] into one or more equations; if not already done by ZM in an earlier thread. I do not have the skill to do so myself.
It follows from your discussion that simplified F6 can be easily and faithfully run in an open loop configuration. All elements, parameters and currents are symmetrical. What is loop feedback correcting for anyway if everything else is close to ideal to begin with?besides lowering Zout]. My simplistic interpretation of the output stage is: The top FET has a voltage gain of 1 [common drain]. The bottom FET has a gain which is greater than 1 [common source]. The load to the bottom FET load is the loudspeaker in parallel with the upper FET operating in the common gate configuration. Thus, the net output voltage into the loudspeaker is not symmetrical due to the different gain of the two FETs working the same loudspeaker. The resulting open loop gain [mostly from the bottom FET] is then partly sacrificed as loop feedback to restore output symmetry and purity; to a net voltage gain of 1. Loop feedback is forcing the voltage gain of the bottom FET down to 1. Or else distortion!
Obviously I don't know the details of the circuit or Xfrmr so I am just guessing too! If all the windings are actually equal (1:1+1) that is a big hint. Is that true? Has NP actually agreed to that. 150 ohm, 600 ohm, or whatever?
:Pawprint:
Is this mean that 1 Vp-p [for example] across the primary winding generates 1 Vp-p across the upper secondary winding and another 1 Vp-p across the bottom secondary winding? If yes, this hints the voltage gain of the transformer is equal to 2.
Going back to thread #38 and its attendant schematic [and explanation] of the bjt OTL;
  • The suggested interstage transformer is step down [6:1].
  • No specific mention in the text of voltage gain of its output stage. Was it inadvertent?
This is diyAudio. Ask all the questions and question all the answers. Look under every stone and make sense out of one's find.
Yes, that could be said to be true. But, in it's application that may not be correct for the circuit as a whole.
Some baseless assumptions on my part: I would expect gain from the bottom FET.
I would imagine the Xfrmr could be 1:1+1 or possibly a higher turns ratio on the top FET.
I would also expect the circuit to work without FeedBack.
:D
:D
All of our threads are food for thought. No harm at all in chewing them over [by inspection] so as to understand how F6 [and other circuits] generally work. Clearly; when Mr. Pass speaks, writes and puts forth a new schematic like F6 and others, everybody listens and reacts to it. 400 + threads! and counting.
Joined 2003
:Pawprint:
who cares what NP have to tell ?
I only care what Pa is telling
:rofl:
whatever - is it 4x600R or is it 4x150R is just matter of friendly dispute between Pa and moi ;
fact is that 2SK170/2SJ74 buffer is able to drive it , be it 150 or 600 (and it is 150 per section :devilr: )
The one and only
Joined 2001
The Jenson JT-123-FLPCH has inter-winding capacitances of 18nF. When these are taken into account, "pure symmetry" is lost because the secondary for the upper FET is moving with the output signal, vs the secondary of the lower FET is at a nearly constant voltage. The result is that the capacitive coupling to the gates introduces significant 2nd harmonic.
Now I understand why 0.1% THD at 1 watt might be expected, unless there are some tricks to be discovered.
I don't think you do understand. The capacitance of the transformer would
only influence the distortion at higher frequencies, not at lower, but when
we look at the open loop (or closed loop) distortion of the F6 prototype
we don't see an increase in distortion at the frequency extremes.
Remember that the quadfilar windings have symmetric capacitance, so all
windings exhibit the same conditions with respect to that.
:cool:
