#2181 |
look at FIG.4B , for instance
Input signal Vi is shown as positive starting voltage signal at base of Q1 that became negative starting Voltage signal on node 102 which means rising current signal through R4 which means rising voltage signal across R4 which means positive starting voltage signal for Q3 base which means negative starting voltage signal at base of Q2 which means Q1 and Q2 are fed with antiphase signals on respective gates which is exactly shown on FIG.3B guyz will hear only difference between upper and lower Jfet modulation , having same-phase connected secondaris which isn't even good for nulling adventures , what demands dynamic condition , not silent ones
my Papa is smarter than your Nelson ! tnx to Last edited by Zen Mod; 1st October 2012 at 06:26 PM. |
#2182 | |
#2183 | |
FIG.4B is Aleph CCS ;
same as FIG.1 , FIG.2 , FIG.3 , FIG.4A , FIG.4B , FIG.5 Pa's post #306 : Quote:
..... what's that having with Aleph CCS patent ? he obviously joked ..... besides that , with your misunderstanding of ALeph CCS patent ,you are implying that he deliberately twisted facts in his own patent , with intention of preventing scamers ? which I have some difficulties to believe .....
my Papa is smarter than your Nelson ! tnx to |
#2184 | |
#2185 | |
I clearly misunderstood the invention US 5,710,522, and thus misinterpreted the operation of the Aleph Current Source. %7#* happens said Arnold's Predator. My apologies to y'all for inadvertently causing negative emotions, frustration and other ill effects. But; my screwup has a silver lining and I am happy to report its upside:
#2186 |
Your crazy!
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#2187 | |||
no negative emotions , I was just somewhat tired showing you that you're splittin' wrong hair Quote:
that's one way of observing the reality (sez that man who sez - gimme support point and I would move the Earth) ; but - contrary to Aleph CCS , F6's "CS" have no any connection with current going to load , which is ,naive me , pretty much important virtue of said Aleph CCS Quote:
F6 Amplifier but , without severe limitation of upper Jfet's modulation , you can hardly have any decent output ; and even then , efficiency of amplifier will be simply awful ; depending of said modulation limitation/attenuation , you'll have anything between total silencer and simple CCS loaded amp so - we are here brainstorming about amp ; nothing more , nothing less but , this isn't 42 chase so - next time , contemplating about some theorem , please put some things in form of question , not fact ...... just because that way you're misleading ppl with lesser knowledge and experience don't be afraid to be dumb ......... I'm exactly that at least 10 times/day
#2188 |
EWE! I forgot about number two.
Never mind. I am going for uber low distortion, then magic SE trick. All will have to wait for completion of M2 bastardo. Nothing like a good fight.
#2189 |
I am rarely afraid and afraid or shy to be dumb or stupid; This clearly showed already with my screwups. Fortunately this is a therapeutic hobby and not my core "science field" I depend on for bread and no trans-fat butter.
#2190 |
then buy any proper repeater and you can try even with pair of IRFP240 what's exactly happening
| New F6 diy coming soon ? | Nounours18200 | Pass Labs | 37 | 31st August 2012 04:35 PM |
| Hi Vi F6 box | ioro | Multi-Way | 4 | 15th April 2012 08:27 PM |
| Whats happening with F6? | jugoslavija | Pass Labs | 1 | 1st November 2011 07:39 AM |
| Hi-Vi F6 | kkosiba | Multi-Way | 14 | 9th November 2007 08:38 AM |
| F6 | traw | Pass Labs | 7 | 2nd November 2007 07:09 PM |
