F6 Amplifier
F6 Amplifier
Old 30th September 2012, 03:56 PM   #2131
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by flg View Post
lhquam, I was slower at the keyboard but, I beleive I agree
lhquam and flg. Clearly you know your stuff; but unfortunately the 'sweet spot' continues to be elusive; although within the near grasp of lhquam per his matching JFET study. ZM showed a picture of the SIT-1 amp with a meter [for Idss?] on the front panel. Is the sweet spot related to a certain idle Idss of the output stage? My thinking in my previous post was as follows by this example: If the upper JFET has a Gm = 8.0 S, then a Vgs = 1.0 Volt enables an idle Idss = 8.0 A to flow through it. By comparison, the lower JFET has a Gm = 7.0 S. So the same matching Vgs = 1.0 V as for the upper JFET, generates an idle Idss = 7.0 A to flow through it. The two JFETs are connected in series, and thus must pass either 7 or 8 A; otherwise create a voltage divider [DC offset]. So, the DIYer tweaks the bias pot of the upper JFET down and/or the bias pot up of the lower JFET to get either 7 or 8 A and zero output DC offset. Except, the range of Idss [of 7-8 A] is where the sweet spot resides; but at which tweakable steady state of idle Idss. Will it be at 7.1 A which is closer to the Gm of bottom JFET or by contrast at 7.9 A. Thus, one has 10 incremental steps = 0.1A Idss [or more or less] to tweak [with the same bias pots] so as to nail this sweet spot down. Except; an attendant output DC offset must develop with each tweak. Can't have your B-day cake and eat it too [your guests took care of it]. Flow with [aka tolerate] this offset to find the sweet spot.
Old 30th September 2012, 04:00 PM   #2132
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
DC offset must remain in safe boundaries , while varying THD content
already shown how to in this very thread
anyway - different constructions , different ways for varying Amount of Zen .... , but none of them is allowed to alter DC offset
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th September 2012, 04:27 PM   #2133
F6 Amplifier
lhquam's search for an answer in the Zen Pot of the SIT amp is an interesting development. Clearly, the issue of device matching is irrlevant vis a vis SIT; a solo performer. Is the Zen Pot tweaking Idss and Vds of the SIT? If the answer is yes, then this tweak is moving or shifting or off-setting Vds [new status] from its parent value before the tweak as one hunted for the sweet Idss point. Uh Oh.. I am saying exactly what you said all along. SIT has a DC output blocking cap, and thus one will easily ignore a +/- 1 Volt shift in its Vds. It is irrelevant to its DC offset; it has none. But a similar DC output shift in offset for F6 clone is not tolerated, and is clearly managed with a blocking cap once its sweet Idss is found.
Old 30th September 2012, 04:44 PM   #2134
Zen Mod's Avatar
F6 Amplifier
speaking strictly about F6 and MR's amp - with pot you're varying degree of either direct AC modulation , or AC degeneration (indirectly influencing AC modulation)
in both cases it's strictly area of AC , while biasing/DC offset is strictly related to static, DC area
so , how's that suddenly connected with DC offset ?
Old 30th September 2012, 04:51 PM   #2135
F6 Amplifier
Please ignore my earlier post because it is not relevant.
Old 30th September 2012, 05:00 PM   #2136
Zen Mod's Avatar
F6 Amplifier
Originally Posted by Antoinel View Post
....do you?
obviously neither you nor I , have enough mileage or knowledge to understand how young or less young Pass was/is thinking ......
sometimes I see something twisty/funny in his schematics , but that's only making me happier , not really smarter ....... but that's not his fault , but mine
Old 30th September 2012, 05:07 PM   #2137
F6 Amplifier
Poetic and wise words. Are the potentiometers in the schematic [L'Amp; A simple SIT Amp] independent or ganged/track?
Old 30th September 2012, 05:12 PM   #2138
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I thought we had this figured out
...Shape the sound , Man!
Old 30th September 2012, 05:19 PM   #2139
F6 Amplifier
The accidental and equal settings of 60% on both of the 10 K pots gave the impresion they were ganged. You are correct. The 10 K pots are independent. One 10 K controls bias [to -10V], the second 10 K which is hooked to the 47 uF cap is the Zen Pot.
Old 30th September 2012, 05:36 PM   #2140
buzzforb's Avatar
You neer to build it and test hypothesis activley.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
