F6 Amplifier - Page 200 - diyAudio
Old 20th September 2012, 01:15 AM   #1991
buzzforb's Avatar
If you remember, this was my suggestion. I agree, this gives greatest freedom and I will do it. I have some pots on order and on the way. Odd thing is, I had more luck moving the cap, vs changing Rs. As for the harmonics, I was referring to post #1969. They seem to indicate distortion characteristics. In my playing with Ba3, I liked a little more second, as it added a little bloom to the sound. I have always found this to sound closer to what i hear in person. Nelson has suggested that it mimics the "asymmetrical nature of air". Where the perfect line is, I don't know, but I like the idea forwarded in the "Leaving Class A" article, where there is a suggestion of adding a little SE bias for low level musical reproduction, and then transitioning to a cleaner, less distorted level, for higher output. It jsut sounds more musical to me. 100% opinion of course. I really souhld take the time to learn something so that i can give some numbers info with my opinion. It seems to be more accepted in a forum like this. Makes sense to me considering the high level of talent found here and their unwillingness to accept normal audio spew.
...Shape the sound , Man!
Old 20th September 2012, 01:23 AM   #1992
Rush is offline Rush  United States
Seldom do I see anyone that is good with "numbers" being able to correlate the numbers to more depth - space, vertical and horizontal, and air around instruments, etc. The harmonics are one thing, the really fun stuff is less about numbers, I think.
Rush
Old 20th September 2012, 01:26 AM   #1993
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
well , one can leave upper one with fixed (non)degeneration , while having Zen Amount pot on lower one
then put pot on front plate , and write SIT 1 wannabe
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th September 2012, 01:30 AM   #1994
Zen Mod's Avatar
I kinda admire this thread
2K posts , still without official schm
I bet we can make 4K
Old 20th September 2012, 01:42 AM   #1995
buzzforb's Avatar
One more!
Definately wannebe for Me!
Old 20th September 2012, 01:44 AM   #1996
lhquam is offline lhquam  United States
ZM: You might be right about 4K posts. I think the schematic has converged, but there is still a lot to learn about how parameter choices affect the sound. I think you are right about the Zen Pot on the front panel, but why only one? Having two pots lets you play with damping factor also.
Old 20th September 2012, 01:45 AM   #1997
buzzforb's Avatar
Rush
I do believe the numbers are important. They help define/explain what it is we are hearing. For me, hearing comes first. This assumes of course, that you have Master ZEN of audio feeding you info and schematics. DiyAudio ROCKS!
+2
Old 20th September 2012, 01:47 AM   #1998
buzzforb's Avatar
At .05 ohms, Ilquuam is basically at no degeneration. Just toss it
+3
Old 20th September 2012, 02:17 AM   #1999
Toss it? I haven't converged to any final conclusion about what sounds best.
What I have been doing is explore the range of measurable performance. Having found that this amplifier is capable of being adjusted to have low 2nd harmonic distortion, with the pots, I can do experiments with listening preferences.
I intend to do exactly what I recommended to you: Rs=0R47 and easily accessible pots. Currently I am using multi-turn Bourns trimmers, but 4 turn shaft pots would be more convenient.
+3
Old 20th September 2012, 03:35 AM   #2000
buzzforb's Avatar
Just having a little fun. I actually think a little degeneration may be better than none, as the sound-stage can grow too much vertically. It is really recording dependent. But that is what is cool. This amp kinda shows you what was done in the audio booth at mastering. I tend to swing more towards ZM's idea of pot across the lower Jfet, leaving the upper alone. Sound wise, I haven't noticed much when switching Rs up top. Ill investigate different values there tomorrow.
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
Copyright 1999-2017 diyAudio
