F6 Amplifier
F6 Amplifier
Old 11th September 2012, 08:15 PM   #1701
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
which cap ?
easy ....... calc for 0.5Hz with adjacent impedance
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th September 2012, 08:35 PM   #1702
lhquam is offline lhquam  United States
I have not directly measured the JFET transconductance, but have measured the output impedance of the Teaser-6 under the following conditions:
Feedback network: 50R/10R.
Closed loop gain approx 4.7
Rs=0, ie. AC coupling directly to JFET source
Rsens=0R12
Ibias=1.3A
Zo = 0R334
Measured open-loop-gain: 153
(Based on AC voltage measurement across transformer primary at 60Hz.
Not sure about accuracy.)
Originally Posted by Antoinel View Post
Thank you Alex and lhquam. What is the value of S and thus Zo for Teaser-6 operating in Class A?
Old 11th September 2012, 10:25 PM   #1703
Antoinel is offline Antoinel  United States
F6 Amplifier
Rsens=0R12
Ibias=1.3A
Zo = 0R334
Thank you lhquam. Actual Zo = 0.334 Ohms = 1/2S. Solve for S= 1.5 mho. Possible right answer?
Old 11th September 2012, 11:18 PM   #1704
I am not sure what you are trying to calculate. The feedback loop must be considered.
The actual transconductance of the JFETs is something like OLG/(2*Rload).
Rload is 8R || 60R approx 7R. We get S=10.77mho. That is consistent with the R100 datasheet.
Old 11th September 2012, 11:30 PM   #1705
F6 Amplifier
I am not sure what you are trying to calculate. The effective transconductance of the amplifier is CLG/Rload = 4.7/8 = .5875. The feedback loop must be considered.
Just playing with numbers. Thanks for your calcs. They are robust.
Old 11th September 2012, 11:31 PM   #1706
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Switched Xformers and changed caps to Elna Silmics II 470uF. Stereo running now. Clean and sweet midrange. Definitely need more gain from Pre IMO. I think or me personally, I would like a little more bloom. Don't know yet for sure. What if top cap is connected below fet and bottom cap is connected on bottom of Rs or attached to pot across Rs? I have an itch to play with harmonics. Also. If i were to run FE off Salas Shunt, how do i take care of the gronuding issue considering two psu's present and two sides of xformer?
...Shape the sound , Man!
Old 12th September 2012, 12:00 AM   #1707
Zen Mod's Avatar
F6 Amplifier
naah
just cascode them ; they're acting as umbrella , no need for special reg
you can play with yay/ney Rs in modulation part
try first upper one to change
Old 12th September 2012, 11:47 AM   #1708
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Default JBL inspired biasing for the F6
Having thought a little bit more, I suggest the following schema as a possible option for the bias.
It is in line with the JBL schema except that where they use a reference diode/zener I think the bias reference (I use 1k2 with an 2SK30 of Idss of 3,1 mA) should suffice.
The bootstrap ensures the current source sees the same potential all the time.
I have a bootstrap both sides just for the sake of symmetry.
JBL Energizer:
JBL Energizer.pdf
  • The diode is a special diode, and as far as I understand it zeners at 1,0V.
  • Else the bias voltage is generated across the 6,2 Ω resistor and the diode just acts as some kind of safety device.
The feedback is local to the driver amp and global, to the input (via a filter that compensates for special JBL loudspeakers).
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 12th September 2012, 12:13 PM   #1709
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
It's symetrical by sight, though i think supplying the bottom voltage source from ground instead of output should be preferable.
(And no bootstrap at bottom)
Old 12th September 2012, 12:18 PM   #1710
triode_al's Avatar
Agree totally - I am just trying to pathethic over a small detail - the compression factor of the CCS, that will influence the operating point. I have no idea if there is a difference; simulation could show that.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
