Old 9th September 2012, 03:29 AM   #1531
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
I expect one or few more tricks from Pa , but it's not mine to reveal them
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 9th September 2012, 03:37 AM   #1532
lhquam is offline lhquam  United States
I am eagerly waiting for them and trying to figure out what they might be. Perhaps I should tweak the circuit and its parameters some more.
Old 9th September 2012, 03:39 AM   #1533
How does this relate to the F6?
just for your amusement
pics of next (semi public) Bfish Ikebana
(we must keep this silly thread alive , or Pa will forget to publish bloody article , to stop this agony )
Old 9th September 2012, 03:46 AM   #1534
Zen Mod's Avatar
we were talking about Ikebana style prototyping
Old 9th September 2012, 06:31 AM   #1535
Banned
All will be revealed on April 1st, 2013
Old 9th September 2012, 11:13 AM   #1536
Originally Posted by lhquam View Post
I suspect the "boomy" sound on the bass is due to a low damping factor of about 4.6. I estimate the output impedance is around 1.7 ohms. The closed-loop gain is 4.7.
Your loudspeakers were optimized by its manufacturer to work with an ideal voltage source amp [Zo <0.1 Ohms]. Now you drive the same loudspeakers with TEASER 6 of higher Zo = 1.7 Ohms. TEASER 6 gave you [and us] the correct and expected answers. Your build is A+. Its got power, low %THD, is stable with no hum and buzz. Unfortunately, its loudspeaker mate is suboptimal. What is Zo for your F5 build?
  • Do know the impedance versus frequency curve of your loudspeaker especially in the midrange; to explain the mud and listener fatigue?
  • The classic designs used a voltage gain stage on the primary side of the transformer. kasey197 used a step up transformer to harness more open loopl gain than available as depicted by Conceptual F6. You also have indicated other options to lower Zo!
Old 9th September 2012, 11:29 AM   #1537
buzzforb's Avatar
That was the point i was mqking earlier.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 9th September 2012, 11:34 AM   #1538
Here is Stereophile Mag's impedance measurement of my B&W CDM1 speakers. Yup, my next tweak will be to lower the output JFET source resistors to somewhere near ZERO ohms, which will increase open-loop gain to around 100 or so. I could also reduce the closed-loop gain below 4.7, requiring an input source capable of higher voltage drive.
Old 9th September 2012, 11:44 AM   #1539
buzzforb's Avatar
Listener fatigue does not fit what i would expect. I would expect smooth and transparent.
Old 9th September 2012, 11:50 AM   #1540
buzzforb. I second you opinion and first point you made earlier. You also build and know loudspeakers very well.
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright ©1999-2013 diyAudio
