F6 Amplifier
F6 Amplifier
Old 8th September 2012, 04:23 PM   #1491
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
it's possible to damage them only if you exceed their Ugs limit ;
chance for that are small - requires idiot driving insane voltage in input
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th September 2012, 04:38 PM   #1492
lhquam is offline lhquam  United States
Default SemiSouth R100 variability
In my previous post F6 Amplifier I show significant THD differences between 2 PC boards I built. Today, I swapped R100 output JFETs between boards (that was easier than swapping transformers). Here is THD vs Frequency of one of the boards, before and after the swap.
This indicates that there is considerable variability between the SemiSouth R100 JFETs. I do not know if it is input capacitance, transconductance, or something else.
File Type: jpg F6-0R47-gain-4p7-1W-sweep-PCB2-Jswap.jpg (120.0 KB, 268 views)
Old 8th September 2012, 05:04 PM   #1493
Zen Mod's Avatar
F6 Amplifier
probably different gate leakage
Old 8th September 2012, 05:23 PM   #1494
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Originally Posted by Zen Mod View Post
...connect top of lower bias net (JfetCCS) to GND , instead to output...
not seen this one but yes.
Two mistakes in the shematic but may be not in the circuit.
Old 8th September 2012, 05:27 PM   #1495
Bad news
Old 8th September 2012, 05:31 PM   #1496
buzzforb is offline buzzforb  United States
buzzforb's Avatar
dunno
but , if made as drawn , lower Jfet can't be biased
Cap is on bottom section as well. Lower Bias network is not attached to ground at top but output. Everything biases perfectly, but i suspect ZM is right, its the tangled mess. Thats what i figured from beginning, as it was thrown together. I will rebuild and retest.
...Shape the sound , Man!
Old 8th September 2012, 05:42 PM   #1497
Antoinel is online now Antoinel  United States
F6 Amplifier
By mistage, the output voltage may reach power rails [and stick] as one JFET opens and the other simulatneously closes; like a switching or clipping situation. Will it affect [damage] the bias circuitry, and especially will this cause DC to flow through the secondaries [and primary].
Old 8th September 2012, 06:23 PM   #1498
At 20kHz 1watt, the RMS AC gate current is about 40uA. I would expect leakage currents to be much lower than that. I seem to recall measuring the gate current as about 2uA when biased for 1.3A drain current. I did that measurement for only one R100 JFET.
Old 8th September 2012, 06:24 PM   #1499
buzzforb's Avatar
Wondering if the R100A parts are showing their colors vs their non A counterparts.
Old 8th September 2012, 06:26 PM   #1500
Yeah, I was thinking the same. I am trying to order some non-A R100s right now from Newark.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
