F6 Amplifier - Page 138 - diyAudio
Old 2nd September 2012, 12:53 AM   #1371
bobodioulasso's Avatar
Given the moderate (turn on) Vgs of the JFets, i think 0R22 for Rs is enough.
Olg isn't penalised too much allowing more feedback aiming to less distortion and a better damping factor etc...
But i might be wrong.
Old 2nd September 2012, 01:33 AM   #1372
buzzforb's Avatar
Thats what i am going with.
...Shape the sound , Man!
Old 2nd September 2012, 02:08 AM   #1373
lhquam is offline lhquam  United States
Correction: I am using SJEP120R100A JFETs. I do not know how they differ from to SJEP120R100 JFETs, but their data sheet says "High Performance Audio".
Originally Posted by lhquam View Post
I do not know if there will ever be a consensus on the "optimal" configuration of parameters. It will depend on personal sonic preferences.
My prototype uses SemiSouth SJEP120R100 JFETs.
Old 2nd September 2012, 02:11 AM   #1374
buzzforb's Avatar
I think they are parts that missed the mark for switching purposes which they were made for.....I think.
Old 2nd September 2012, 02:16 AM   #1375
I thank you for that suggestion.
The source resistor has two different effects:
  • 1) degeneration - local negative feedback.
  • 2) bias voltage stabilization - and ability to measure bias current.
Instead of one source resistor, consider 2 in series with the top resistor controlling degeneration (possibly zero ohms) and the bottom resistor supplying the additional voltage drop for bias stability. The node between the 2 resistors connects to the bottom of the transformer secondary (the "modulation node").
Originally Posted by Zen Mod View Post
and you can modulate them from bottom of Rs ....... or from top of Rs ....... or one from bottom and other from top ....... or the other way around .........
Old 2nd September 2012, 02:40 AM   #1376
buzzforb's Avatar
Like SRPP. Where/how you pull from determines all sorts of things
Old 2nd September 2012, 03:31 AM   #1377
BudP is offline BudP  United States
BudP's Avatar
Nelson, a question for you please.
When you chose the impedance match to the primary of the transformer as input device, what guided you to 600 ohms? Will a higher impedance / inductance/ DCR cause undue distress? I have a pair of 2800 ohm split primary and secondary transformers, 48% nickle core and pin out to match the Jensen parts. I can also have 1200 ohms or 600 ohms or whatever is best. Can you provide some guidance please?
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 2nd September 2012, 09:49 AM   #1378
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
as my , always modest , chip in ..... ( just to mud the water before Pa's answer ) -
those so called 2K8 , instead of so called 600R , will present even more uniform load to input buffer while still having more than enough muscles to fed output gates
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd September 2012, 12:11 PM   #1379
buzzforb's Avatar
Ill let everyone know how they sound.
Old 3rd September 2012, 03:30 AM   #1380
buzzforb's Avatar
Here is MY Franken6. I got most of the way, but alas,not finished. Switched caps to the on hand 220uF. Ill try to throw it together, but things are going to get thick around here for a week or so, so we will see.
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
Copyright 1999-2017 diyAudio
