F6 Amplifier - Page 137 - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 1st September 2012, 12:13 PM   #1361
Originally Posted by buzzforb View Post
Increasing Rs usually lowers DF buy reducing gain. Dont know about here.
Thank you buzzforb. I misunderstood it as the opposite. How's your build coming along?
Old 1st September 2012, 12:19 PM   #1362
buzzforb's Avatar
I could be wrong, but i think thats right. My build is slow because i am shipping F5T kits monday. I have the screwed up version close, but dont know if ill get to it.
...Shape the sound , Man!
Old 1st September 2012, 02:06 PM   #1363
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
screwed or screwed ?
I hope one , not the other
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st September 2012, 02:20 PM   #1364
buzzforb's Avatar
Maybe poor implementation is better description. I got FE looking like F5T input with signal coming out of source and then in the output stage, I got the big 10uF caps instead of 1000uF's like Ilquam. It is CCS loaded LEd's fro bias voltage on output. Rs is 22R and gain is set at about 10. I am using laterals because they are close to SS in bias voltages and if i blow them up, I dont feel as bad.
Edit:
Why the need for large caps? Are they forming a high pass on top ot blocking dc through coils?
Old 1st September 2012, 02:51 PM   #1365
Zen Mod's Avatar
secondaries are low impedance jobies
even if they're looking at 10K load (Pa sez that) , better to put nice biggie Silmic in series with them
bigger is sometimes better
Old 1st September 2012, 02:55 PM   #1366
lhquam is offline lhquam  United States
I hope you meant to say "Rs is 0R22". The large caps reduce the modulation of the bias voltage by the signal. I may have used excessively large caps, but I suspect 10uf is too small and will increase low frequency roll-off.
Edit:
Old 1st September 2012, 03:03 PM   #1367
I just ran the simulation again and equation to calculate output impedance. Increasing Rs increases the output impedance, thereby decreasing the damping factor. Increasing Rs also lowers the voltage gain of the output stage, thereby lowering the open-loop gain. Is closed-loop gain is held constant then the amount of negative feedback is reduced which also decreases the damping factor. The 2 effects are not really multiplicative, but I do not have the equations in front of me that shows the general case with feedback.
Originally Posted by Antoinel View Post
lhquam: I am glad you are connecting the subjective "sonic signature" of the amp to its objective and measureable parameters. So, your reference loudspeaker will sing with a different voice which is discernible to you with each substantial [and maybe not] tweak. Clearly one "sweet" voice [to your hearing] will eventually stand out and be adopted.
Please reconfirm in your table of parameters the following. Will increasing Rs increase or decrease damping factor? Thank you.
Old 1st September 2012, 03:51 PM   #1368
lhquam. Thank you for the correct answer. I had the underlined backwards [reversed] in my head for a while. You have several variables to "juggle" to nail the optimal and final status of the amp. Based on past publications by Mr. Pass, and Mr. Rothacher, the general sound character of your amp is expected to be "pentode-like" versus triode-like if the output stage devices were SIT instead of JFETs. Have you built a SIT amp according to the Rothacher DIY?
Old 1st September 2012, 04:39 PM   #1369
I do not know if there will ever be a consensus on the "optimal" configuration of parameters. It will depend on personal sonic preferences.
My prototype uses SemiSouth SJEP120R100 JFETs.
Old 1st September 2012, 06:02 PM   #1370
The official schematic of F6 will embody design variables which express a unique sonic signature that is solely attendant to the preferences of Mr. Pass. He is listening to the voice of his assembled F6 through his loudspeakers [unknown make] playing his preferred music [unknown] in his music/test room of unknown dimensions, surface treatments; with or without suppression of standing waves etc. Thus, he has geared his F6 to his listening pleasure, plus the other important technical and business pursuits. He may already have cast his design in stone, and thus gave it Universality. What is the probability that the sonic signature of his official F6 is like that of a DIY build of F6 DIY using his schematic? I say very good to excellent. Fortunately, the above also holds true for your design, triode_al, buzzforb, bobodioulasso and countless others, as y'all have also tweaked your listening environment [and support electronics] which are an integral part and parcel of the sonic signature of the amp. There will be a lot flexibility in design to suit as underlined in your text. Just like the old classic [based on the wimdehaan-Tent Circuit] which came in many renditions and topologies!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
