F6 Amplifier
F6 Amplifier
Old 31st August 2012, 03:41 PM   #1341
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I have considered this, but it may alter characteristic or intended sound of amp.
...Shape the sound , Man!
Old 31st August 2012, 05:02 PM   #1342
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 31st August 2012, 08:05 PM   #1343
buzzforb's Avatar
Originally Posted by Zen Mod View Post
why not ?
see ; +/-20V arbitrary - written for then actual chat
later I saw interesting idea too - called Hawksford buffer (second pic )
plain one is cascode voltage biass referenced to gnd , H. same referenced to sources - having as result that jfets are working in real constant voltage mode
search to read what's difference - lower output impedance , if I remember that well
didn't measured , didn't tried
The Hawksford circuit is what I am going to have driving the FE of my F6 and I have some questions. First concerns the Vref for the BJT. Based on history and whats out there, I was thinking that 5-6 LED's would be better, as this would put the Jfets in the 10V range that they seem to like. It would also allow them to be run at full Idss with no worries. Second; in Joachim's layout, he has a switch at the ground point of the LED's and Jfet sources. Is this meant to be a relay initiated thing? Third, based on Nelson and others comments, if matched Jfets were used, the source resistors could be dropped, correct. I have a place in the pcb to add an offset pot as a safety margin, but would like to go without it.
Edit: Great thing about the circuit is the fact that it can be built as per the original schematic with jumpers and then added to, testing along the way, and checking for improvements in either measurement or sound.
Old 31st August 2012, 08:08 PM   #1344
Zen Mod's Avatar
F6 Amplifier
lazy Yank
give me proper pic
(just ignore that I have it somewhere in comp)
Old 31st August 2012, 08:09 PM   #1345
buzzforb's Avatar
Thought it would come over with quote. Still haven't learned anything.
Old 31st August 2012, 08:11 PM   #1346
Zen Mod's Avatar
F6 Amplifier
open pic , collect link of it , then put it here with "insert pic" command
Old 31st August 2012, 08:14 PM   #1347
buzzforb's Avatar
Its there in the original post now. Did it while you were making fun of me
Old 31st August 2012, 08:27 PM   #1348
Zen Mod's Avatar
F6 Amplifier
Old 31st August 2012, 08:32 PM   #1349
Zen Mod's Avatar
F6 Amplifier
The Hawksford circuit is what I am going to have driving the FE of my F6 and I have some questions. First concerns the Vref for the BJT. Based on history and whats out there, I was thinking that 5-6 LED's would be better, as this would put the Jfets in the 10V range that they seem to like. It would also allow them to be run at full Idss with no worries........
shortly - yes
.... Second; in Joachim's layout, he has a switch at the ground point of the LED's and Jfet sources. Is this meant to be a relay initiated thing? ....
jumpers, switch , or whatever - make it one or another way ...... but make it switchable between both ways , to hear what's your bloody preference
......Third, based on Nelson and others comments, if matched Jfets were used, the source resistors could be dropped, correct. I have a place in the pcb to add an offset pot as a safety margin, but would like to go without it.
10R trimpot can't do any harm ; you can easily toss it out
Old 31st August 2012, 08:47 PM   #1350
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F6 Amplifier
This will oscillate as presented - try putting some Gate stoppers on the Jfets.
Of course with a small amount of Source resistance on each, say 10 ohms,
and a lower supply voltage you can dump the cascoding altogether.
Can you say Beast With a Thousand Jfets?
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
