F6 Amplifier
F6 Amplifier
Old 30th August 2012, 04:33 PM   #1281
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
F6 Amplifier
http://www.diyaudio.com/forums/pass-...ml#post2793558
Old 30th August 2012, 04:37 PM   #1282
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
.... just as example
boyz , stay on topic , please
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th August 2012, 04:39 PM   #1283
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by lhquam View Post
Sure, the input stage could be something other than a complementary follower, but I think there are good reasons for that choice. The input stage needs to have a fairly low output impedance, because of the load imposed by the transformer, which is about 100R at 20Hz and 200R at 40Hz. This suggests a complementary follower stage rather than common drain. Sure, an opamp could be used and would provide the benefit of more voltage gain. But that would lead us off of the Pass Path.
in my opinion gain is not needed and the jfet follower the F6 has just passes the signal on in two directions, enough (like 0 dB - 700 mV RMS while the transformer and the input buffer can go up to +20 dB) to saturate the output stages far above the 2,4V max and deliver linear behavior.
So this is the Pure Pass Policy: keep it simple.
The input config (jfet follower or like Jensen shows in its appl notes with an opamp) is trivial.
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 30th August 2012, 05:28 PM   #1284
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by Zen Mod View Post
OPA1632 is SUSY chip - diff in , diff out
it demands pretty lowish impedance feedback net, and it's having low output impedance
I was using it connected to sec of Beyerdynamic 1:10 mic xformer ; xformer ditto on outputs of two (diff connected ) PCM1704 , then feedback net defining reflected impedance back to chips , to have linear freq through audio band
driving xformer with small bridge power amp , to drive output of small power amp ........
........ may I laugh ..... just a little ?
Absolutely ZM; please do; it'll lower your blood pressure. Did you slip above and call Conceptual F6 a small power amp [bolded]; how big?. That's the trick. Make ZM laugh and hell reward you with free info.
Old 30th August 2012, 05:32 PM   #1285
Zen Mod's Avatar
F6 Amplifier
naah .....
what's one small,redundant,power amp ....... between friends ........
Old 30th August 2012, 05:47 PM   #1286
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Not meant to be OT, but I was thinking that beautiful SUSy chip with really nice distrtion numbers and low output Z would be kinda cool driving x-former symmetrical output stage. Somewhat redundant, but not altogether ridiculous. This is DIY.
...Shape the sound , Man!
Old 30th August 2012, 05:52 PM   #1287
Zen Mod's Avatar
F6 Amplifier
well - if you need some gain , you can really put it instead of buffer and make nice integrated , with ball input
you can then connect two primaries in symmetrical manner , with overall FB connected from their CT to gnd (need to check that on paper , but seems logical in this moment )
but - do not forget that 1632 (and TSHA cousins ) like lowish impedance NFB net , resulting in lowish input impedance ; you need ball$ to drive it , too
Old 30th August 2012, 05:56 PM   #1288
buzzforb's Avatar
Yup. got lots of bal...I mean preamps capable of that.
Old 30th August 2012, 06:01 PM   #1289
Zen Mod's Avatar
F6 Amplifier
Originally Posted by Antoinel View Post
A....... Did you slip above and call Conceptual F6 a small power amp [bolded]; how big?.......
certainly
with usual FW PSU it can't be big - 25W/8 and 50W/4
Pa mentioned scaling ....... I think at least up to 3 pairs can be driven easily , with good results ; PSU voltage of OS can be at least double
so - 100W/8 is easily obtainable
Old 30th August 2012, 06:03 PM   #1290
Zen Mod's Avatar
F6 Amplifier
then you have double naked situation - you don't need OPA for gain ...... and using it instead of simple and effective buffer is .......... just imagine number of small critters packed in chain , due to necessary compromises in construction of every chip
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
