F6 Amplifier
F6 Amplifier
Old 29th August 2012, 02:01 PM   #1251
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by lhquam View Post
I think I have stumbled onto the secret of the F6.
Parastroika! I understood it [back in the 1980s] to mean openess which you are doing.
Old 29th August 2012, 07:12 PM   #1252
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
R2=1k looks very strange.
What signal is left to the primary?
Old 29th August 2012, 08:34 PM   #1253
lhquam is offline lhquam  United States
My stupidity! The THD numbers were correct, but I neglected to notice that the output voltage was being reduced approximately by the ratio of the Z/(Z+R2||R1) where Z is the transformer impedance.
In fact, impedance curves show just the opposite: the input driver impedance should be low in order to flatten the output frequency response curve. In earlier posts, Zen Mod discussed the importance of secondary loading. Here is the transformer V(sec)/Vin vs frequency for different values of Rsec. From bottom to top they are 100R, 200R, 500R, 2K, 1meg. At 100R, the 20 Hz rolloff is only -.18dB vs. -.47dB with an Rsec=1meg. Unfortunately, secondary loading also reduces the open-loop gain.
Old 29th August 2012, 10:16 PM   #1254
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
sim/calculate for prototype
then listen and measure
accent on listen
my remarks about importance of secondary loading are staying carved in stone , but if Pa is saying that SS gate impedance is low enough and flat enough for exact Jensen type , I would not argue for a second
especially if I'm not having Jensens on hand
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th August 2012, 11:48 PM   #1255
accent on listen
Those Jenson trannies seem to be very good. Here are scope photos of the square wave response.
The first image is for a 1MHz square wave from a 50 ohm generator directly into both primaries and no load on the secondaries. The bottom trace is voltage across the primary. The top trace is voltage across the secondary. Horizontal scale is .2us/div.
The second image is for a 100kHz square wave from a 50 ohm generator directly into both primaries and 1nF load on the secondaries (similar to the SS100 JFETs). The bottom trace is voltage across the primary. The top trace is voltage across the secondary. Horizontal scale is 2us/div. There are some artefacts, but I would not call it ringing.
Is that a good transformer?
Old 30th August 2012, 02:31 AM   #1256
Does anyone know how much DC current through the transformer primary can be tolerated without added distortion? The question is motivated by the issue of the input JFETs not necessarily being well matched in IDSS. A potentiometer could be added to trim the input stage offset voltage at the cost of increasing the impedance driving the transformer.
Old 30th August 2012, 03:55 AM   #1257
Here is a plot of open-loop gain vs. frequency. Too much roll-off at high frequencies for a no feedback amplifier.
Originally Posted by buzzforb View Post
I have a fondness for no feedback designs. Try it without any and see if it is stable. Should be able t run the Pspice pretty easy, as you seem to be the bloody master of that program. DF wont be good, but plan to use it on FR with another amp driving woofers.
Has crazy, ridiculous thought today. OPa1632 feeding transformer. Fully differential input stage is definitely overcomplicated
Old 30th August 2012, 05:57 AM   #1258
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Is that F5 nein?
Fsechs nein nein -the moderator does not accept that
SPU --> tube MM/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT
Old 30th August 2012, 07:50 AM   #1259
Some square waves from the output of your proto, Ihquam?
Old 30th August 2012, 08:45 AM   #1260
Zen Mod's Avatar
F6 Amplifier
do not bother yourself - just make input buffer careful as usual
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
