F6 Amplifier
F6 Amplifier
Old 27th August 2012, 05:36 AM   #1191
lhquam is offline lhquam  United States
Originally Posted by Nelson Pass View Post
Another thing, your thd vs frequency plot tells me that your C4 and C15
values are low.
OK. My capacitor selection is somewhat limited, but I have some electrolytics scavenged from a PC power supply. These are extreme values: 4700uF! They seem to work well but the THD vs Freq plot is about the same as the right hand plot in post #1178. I have not managed to trigger any oscillation. With an RC of 47 seconds, it takes a long time get reach bias voltages (like 5 minutes). I will obtain and try some other cap values like 100uf and 200uf.
Old 27th August 2012, 06:42 AM   #1192
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by lhquam View Post
I just re-verified that the circuit built to this schematic will oscillate about about .5Hz when stimulated by about .5V at .5Hz.
Correction: The input cap is not shorted in the circuit tested.
why are C4 C5 different (22μ vs44μ)?
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 27th August 2012, 07:55 AM   #1193
triode_al's Avatar
lhquam,
  • imho the real reason for the effect might be that
  • you use a bootstrap for the top bias
  • the bias of the top is C4, 44μF connected to the output (and I just note that value differs from C15).
  • sonically this is an electrolytic in the signal path!!
  • an alternate method would be to connect the bias to the output and insert a big bootstrap in the middle of the R20 (1k4+1k4) (and treat it similar with SAME cap in a split up R21).
Q:
if you disconnect the transformer from one of the outputs does it still oscillate/motorboat?
- just for instance the top one gets no modulation, it will be a BA-1 output stage.
I like a method of bias with just a MP cap!
Old 27th August 2012, 01:11 PM   #1194
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Should be (if well understood)
Old 27th August 2012, 01:34 PM   #1195
Antoinel is offline Antoinel  United States
F6 Amplifier
Wow!
With gain=1, the Bode plot phase margin will be 180 degrees. All of the open-loop gain is going to negative feedback. This will not oscillate.
Obviously a voltage gain stage is needed ahead of the input stage if it to be driven "ordinary" audio sources.
What closed loop gain do you think is appropriate for this amplifier?
Your finding that a CLG = 1 gives a stable amplifier is an eye opener, but is counter to that commonly known. Why is it not oscillating? Please post your refined schematic after implementing the suggestions by Mr. Pass.
Old 27th August 2012, 01:44 PM   #1196
F6 Amplifier
Your schematic is pleasantly simple. Does the underlined mean after implementing [or not] the suggestions of Mr. Pass in your original schematic?
Old 27th August 2012, 01:47 PM   #1197
Yes, after implementing the suggestions of Mr. Pass
Just trying to abstract all datas.
Bigger caps and no cap across zenners.
Not different from Ihquam schematic but drawn differently.
Old 27th August 2012, 02:32 PM   #1198
F6 Amplifier
Wow!
lhquam: Recall that kasey197 has used a step up transformer [other than Jensen] to further increase OLG without an additional gain stage in the front end.
Old 27th August 2012, 03:07 PM   #1199
Nelson explained that he made a typo in post #1182 and was not suggesting a closed-loop gain of 1. I will proceed under the assumption of a gain of around 6.
Old 27th August 2012, 03:18 PM   #1200
F6 Amplifier
Originally Posted by triode_al View Post
lhquam,
Q:
Does the underlined mean metalized polypropylene? Are you still working with your schematic in post#1023.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
