F6 Amplifier
F6 Amplifier
Old 26th August 2012, 12:40 PM   #1141
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by lhquam View Post
I am not sure what the relevance is for "AC ground". What is important are the bias voltages relative to the bottom of the FET source resistors. We are trying to maintain these voltages at constant levels under varying signal conditions.
The AC drive signal to the upper JFET will be relatively larger in magnitude than for the lower JFET. In your opinion is it or not?
Old 26th August 2012, 12:50 PM   #1142
buzzforb is offline buzzforb  United States
buzzforb's Avatar
ZM, Why will it go bottatboom? Dont understand.It is used as Vref for so many bias circuts for transistors.
...Shape the sound , Man!
Old 26th August 2012, 12:54 PM   #1143
Rush is offline Rush  United States
The AC drive signal is the same for both secondaries of the transformer (they don't know how they are being used). If you have a different resistance across one of the secondaries you may change the amplitude.
Please explain how could the AC drive signal be different in the secondaries?
Rush
Old 26th August 2012, 01:04 PM   #1144
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
Originally Posted by Zen Mod View Post
you need to change places of leds and CCS
read what I wrote about 6k8 res on bobbo's sch
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 26th August 2012, 01:11 PM   #1145
buzzforb's Avatar
Choice of Rs on output stage has affect on values of bias network. Is it in parallel with bias network?
Old 26th August 2012, 01:15 PM   #1146
Zen Mod's Avatar
F6 Amplifier
no
, it isn't in parallel
it is important for for needed bias voltage span which you're having on trimpot
without Rs - say that you need 1V5 max
with Rs=0R47 and Iq=2A , you need 1V more
Old 26th August 2012, 01:23 PM   #1147
buzzforb's Avatar
Damn, i amignorant. If i use 2sk246, I can run at Idss, correct. Should i use1K resistor above to help with dissipation?
Old 26th August 2012, 01:36 PM   #1148
Zen Mod's Avatar
F6 Amplifier
you can waste at least 50% of PSU voltage on additional resistor
Old 26th August 2012, 01:54 PM   #1149
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
now choose Rs value & Iq , and calculate that in.
ZM will allow at least 1mA through trimpot , and 3mA through zenner
Old 26th August 2012, 01:55 PM   #1150
Zen Mod's Avatar
F6 Amplifier
go and build
say tnx! to Pa
if you can't find 3k trimpot - use 2K one , and 1K resistor below
and yes , you can use more than 10uF in series with secondary
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
