F5 question
1 Attachment(s)
Good People,
In the DIY store F5 boards I'm using there are 2 groung markings- Why two ? Do I connect the ground (one or both of them) from the board directly to case earth or to the CL60 which then then goes to eart? Thank you all IK |
one to speaker negativ. one to PSU gnd. gnd from PSU to earth thru a CL-60:)
or you can run speaker negativ directly to PSU gnd too. |
Got it
Thank you for such a quick responce :) IK |
You always want to use the power supply star ground for the speaker negative and the ground on the board.
Thank you Labjr
I'm at, it just to be sure i'm using 10K resistors for R21 22 is that okay? or should I change it to 22K Thanks IK |
| All times are GMT. The time now is 12:46 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
