OTL-driving of very low impedance full range ribbons is and remains still a challenge.
Most reliable option for driving of such full range ribbons are power amps with single ended output power stage because the obtained output power is not dependend from the load impedance (current drive). From this view this is the best solution, because there is no risk for destroy the power MOSFETs in the output stage. Unfortunately the output power from the largest me known commercial single ended power amp is the Aleph 1.2 - go to Pass Aleph 1.2 monoblock power amplifier Measurements | Stereophile.com If I want more output power in this kind, presently only a diy solution is the way, because such commercial amp units are not available. Well, what happens in case of the use from the X/XA/XS power amp series? As I know, in this models only push-pull output stages are in use. This means, either a protection circuit switch off the signal to the speakers or several fuses blown away. But what about an additional impedance matching transformer (1:4 until 1:8) ?? I know, the sizes and wight must be very large. OTOH - two great advantage I will get: an ultimate DC protect and the use of each power amp without trouble cause not uncontrolled signal current flow. Who are suppliers and manufacturers of such transformers? About the follow URLs I don't read appropriate informations: Apogee Scintilla amp Apogee ribbon questions... Apogee Ribbon Repairable? Help! Apogee Scintilla capacitors Apogee Scintilla - Information about the Efficiency wanted Last edited by tiefbassuebertr; 20th July 2012 at 06:05 PM. |
| Apogee Scintilla - Information about the Efficiency wanted | tiefbassuebertr | Planars & Exotics | 41 | 17th January 2013 05:59 PM |
| Apogee Scintilla amp | Thomas B | Pass Labs | 27 | 7th July 2012 04:12 PM |
| Apogee ribbon questions... | george a | Planars & Exotics | 18 | 17th November 2011 08:07 AM |
| Apogee Ribbon Repairable? Help! | Bernie7 | Planars & Exotics | 5 | 30th July 2011 02:42 AM |
| Apogee Scintilla capacitors | Dr.H | Planars & Exotics | 9 | 7th June 2009 04:35 PM |
