I still have the hum as mentioned in the previous thread I started.
Can anyone comment on this :- The light bulbs dim when a source is connected to the input. I can get output from an MP3 player and it sounds very nice (apart from the hum )But when I put a passive pre-amp in betweenmsource and de-lite the light bulbs go out and I get no sound. I am wondering whether R4 (1 ohm resistor) Is causing problems. I am using a wirewound 3W. I think that NP used the same 1ohm resistor as he used in the power supply and as this has to dissipate about 20W. The 3W resistor gets quite hot, but has not failed. I have some high power alu cased 1ohm resistors. Is it likely that the 3W is not man enough for the circuit? |
#2 |
I didn't search and I can't remember previous thread
please , post exact schmtc you use , and some pictures my crystal ball is muddy these days
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3 |
#4 |
pics
#5 |
Nothing to show in pics. I have built the thing as per the schematic.
This may help? Version 2 The first effort works, but with the high distortion, it's hard not to want to monkey with it. After you have basked in the glow of accomplishment and light bulbs for a while, perhaps you will feel ready for a little more effort. In this case, that means a couple more parts. Placing a power resistor on the Source of the Mosfet will lower the gain and distortion. After a little testing, I settled on a 1 ohm power resistor, as seen in the schematic of Figure 5. Frugal guy that I am, I used the same resistor as in the power supply. |
#6 | |
either some part , or your implementation I can't be sure what's the culprit , without proper information
#7 |
Ok Zen mod. I can post pics, but I did this before about 2 years ago, but no one had any idea about the problem I had then i.e that it didn't work, light bulbs did not light. I was using the IXYS 6N Fets.
I have now rebuilt the modules using IXYS 20N Fets and have some success as outlined in my first post. I have had someone check the modules and they agree that all parts are connected as on the schematic. The light bulbs used are 300W 130v. ![]() ![]()
#8 | |
For the hum , if they are 2 separated power supply arrangement , it should be seen how the ground are connected . It is better ( imo ) to connect the 2 channels together at the output of the amp . A bad ground "scheme" could produce hum . For the fact that the amp dim when connectin a source , check the input capacitor also . s Edit : For a decent s/n ratio I needed 150.000 uF / channel . 96dB speakers , it is dead quiet . Last edited by stefanobilliani; 13th July 2012 at 08:24 PM. Reason: adding information |
#9 |
Voltage is 80v as per diagram 5.
Something is pulling the voltage down? What you normally get when you hold a phono input lead is a hum through the speaker. I get no noise at all? Last edited by Puffin; 13th July 2012 at 08:29 PM. |
#10 |
| De-Lite grounding | Puffin | Pass Labs | 35 | 5th July 2012 05:58 PM |
| De-Lite Amplifier | Nelson Pass | diyAudio.com Articles | 35 | 3rd June 2012 08:37 PM |
| de-lite mosfets ixth6n50d2 | bjcwolters | Parts | 0 | 3rd August 2011 10:40 AM |
| Hoping somebody can help with De-Lite build? | cddeluca | Pass Labs | 3 | 11th July 2010 02:14 AM |
| Snow De-Lite | skidave | Pass Labs | 12 | 12th February 2010 06:35 PM |
