De-Lite strange problem
Old 25th July 2012, 05:59 PM   #21
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Given that you are having problems, you would want Fig. 10, assuming that
you are using a depletion mode part.
Also given that you are having problems, perhaps you should insert a 100
ohm or so resistor in series with the Gate of the Mosfet.
The idea that it works with one source and not another is quite suspicious.
Measure some of the DC voltages for us.
Old 25th July 2012, 06:23 PM   #22
Puffin is offline Puffin  United Kingdom
I think I have solved my problems. It was ZenMod who caused some doubt.
Nelson. What I don't understand is :-
I have built the amp as per Fig 5. This suggests that this is an "improved" version of the first iteration. Fig 10 is an "icing on the cake" working (as far as I can see and suggested that this equals a 300B amp).
Are you saying that unless I build as per Fig 10 I am wasting my time?
I am using 20N FETS. I am pretty sure that the circuit is NOW working correctly. I will measure the DC voltages.
Rob.
Old 25th July 2012, 08:40 PM   #23
The one and only
If the "Improved" example biases up properly, you're good to go.
Old 25th July 2012, 08:52 PM   #24
OK. Will report back in the next few days. Thanks for your help.
Rob.
Old 26th July 2012, 03:52 AM   #25
ziggyr is offline ziggyr
Hi Nelson, what do you think about my latest circuit(sorry about the lousy schematic drawing) which has been built and works incredibly well with two way large horns.
Any idea on output power?
Old 29th July 2012, 11:27 AM   #26
Ta Da!!! It is done (apart from a very slight mains hum) will increase the PS caps.
Now to tidy and pretty it up.
Old 2nd August 2012, 11:39 AM   #27
I am still having hum problems. Would this amp benefit from a split rail supply as per the
F5?
Old 2nd August 2012, 11:48 AM   #28
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
caps are too far from active circ
put them in same box
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd August 2012, 11:54 AM   #29
Put the PS cap banks close to the power amp circuit?
What about split rail? I have all grounds in with -volts?
Old 2nd August 2012, 12:03 PM   #30
Zen Mod's Avatar
conditio sine qua non , besides proper wiring scheme
What about split rail?....
in your case , thats of secondary importance
.....I have all grounds in with -volts?
clarify
De-Lite strange problemHide this!Advertise here!
De-Lite Amplifier Nelson Pass diyAudio.com Articles 40 31st December 2017 07:51 PM
De-Lite grounding Puffin Pass Labs 35 5th July 2012 06:58 PM
de-lite mosfets ixth6n50d2 bjcwolters Parts 0 3rd August 2011 11:40 AM
Hoping somebody can help with De-Lite build? cddeluca Pass Labs 3 11th July 2010 03:14 AM
Snow De-Lite skidave Pass Labs 12 12th February 2010 07:35 PM
