#31 | |
Again - I stole the idea of gluing the electrolitcs down with hot glue and wiring them P to P from a Blue Circle BC 1022 power amp. The BC1022 An Exceptional Solid State Stereo Power Amplifier New Sounds Audio The case and electrolytics were cleaned with alcohol (not beer) and the bond is so strong now, I don't want to risk trying to pull them off. In hind site - think I would have used water based contact cement. P to P wiring of the electrolytics is a good technique. However, its important there is good metal to metal contact before the solder is applied. Bridging conductors with solder is not good. However - I suspect soldering probably needs to be fast before too much heat damages the caps. BTW: I used Cardas Quad solder - which has lead in it - yuk - but it flows quickly. . . . |
#32 |
Before I get anymore Hazing - 2 corrections
1) The Bandwidth of the F5 is around 800 KHz - not 800MHz 2) In the F5 Turbo tutorial - N.P. did not write that he paralleled up Q1 and Q2 - my mistake . |
#33 |
Juma was right.
When the 0R1 source resistors were removed - and replaced with 0R47, the F5 became thermally stable. Its very well behaved now. Unfortunately - biased at only 0.5 Amps - and there is about 40 mVpp ripple on each supply rail. Very disappointing - I thought only women could break my heart. This is a new power supply - will it improve if the electrolytics break in ? . Last edited by Uunderhill; 8th July 2012 at 06:27 PM. |
#34 |
first tell us just one thing :
check with ohmmeter do you have electrical contact between base plate of PSU and that upper Al plate ? I know that I'm boring , but - as long is there possibility that you have starved PSU , there is no point in any sonic evaluation
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#35 | |
As a short term solution - I removed one of the bolts. Long term solution - probably make a single plate for each donut. . Last edited by Uunderhill; 8th July 2012 at 07:31 PM. |
#36 |
good
double input Jfets , halve source resistors , halve feedback resistors , crank bias then listen
#37 | |
Turn other toroid around, and you is in Doo-Doo. (me always talk in first-person narrative, similar to "We, the King", but in my case "I, the Idiot")
Not so much,.......if it says "ZM" in the corner. Last edited by jacco vermeulen; 8th July 2012 at 08:13 PM. |
#38 | |
H/K 7600 CD player ==> Musical Fidelity v3 tube buffer ==> F5 Amp ===> scope & 10" Tannoy changing one variable at a time 1) paralleling up the input jFET's increased the bass, dynamics and the music moved more forward. Unquestionably, this mod is a keeper with the Gamut style MOSFET's. 2) The source resistors are presently 0R51 - I don't have 0R22's. But from previous tinkering, I know there will be more bass if this value is lowered. 3) The 4 F.B. resistors were always 50 = R5 // R6 and 50 = R7 // R8 4) I moved the bias up to 1.3 Amps - I think it sounded more alive ??? Notes When the bias was increased to 1.3 Amps - the ripple on the supply rails increased to 90 mVpp - not good The amp is very thermally stable - when I switch it on, the voltage drop across the 0R51 source resistor is about 0.64 v 1/2 an hour later its 0.70 v Switching on and off the F5 is very well behaved - no thump - no output hitting the voltage rails. No output relay required. 92,000uF per channel should throw a 10" Tannoy around like there is no tomorrow. But there is no bass. . Last edited by Uunderhill; 8th July 2012 at 10:33 PM. |
#39 | |
Yes your Magisty. . |
#40 |
when I wrote halve source resistors I meant on input Jfet's resistors
that way you'll keep right current through all input jfets , and better drive of outputs also - to keep CLG in ballpark , that's why I wrote to halve feedback resistors too
| Gamut D200 clone !!! | ANALOG GUY | Solid State | 69 | 16th August 2012 04:19 AM |
| Gamut amplifier | jouch | Solid State | 24 | 15th August 2012 06:44 PM |
| DIY home etched boards, old style, simple, fast and SMD style | destroyer X | Solid State | 51 | 11th April 2011 09:07 PM |
| Gamut audio | ben goh | Pass Labs | 14 | 5th March 2007 10:32 AM |
| gamut amp | brian t | Solid State | 1 | 10th August 2002 11:37 AM |
