Help with F5 with Gamut style MOSFET's
Old 8th July 2012, 07:05 AM   #21
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I can't go through drawing all that ....... 30-th time .........
believe it or not , and search
having electrical short circuit through toroidal xformer isn't a wise thing .
magnetic properties of screw material doesn't have anything with exact problem
just iimagine piece of wire , made of base plate +left screw+Al plate +right screw+base plate again ;
isn't that short circuit , going through (any & both ) toroid ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 8th July 2012, 07:11 AM   #22
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
and stacking toroids would do the same ?
this means that two toroids shouldnt even be close to each other ?
but spreading them would cause issues as well ?
well, I have always preferred seperate monos anyway
and 'lifting' the toroids with very thick rubbers
and using non metal top plate
Old 8th July 2012, 07:22 AM   #23
Zen Mod's Avatar
boys
be serious when serious things are in question
you can stack 2 or zillion of them , that don''t have anything with electrically short circuit , which is main issue here ..
just imagine properly mounted toroid in case : screw from bottom plate , going through toroid center , then small top plate (rubber plates I'm not counting this time ) .
then use your green-yellow wire , connected to one point of chassis already , and connect it to top of toroid's screw
what's happening ?
Old 8th July 2012, 08:36 AM   #24
dobrivoje is offline dobrivoje  Serbia
OK, let's solve it in simple way. The additional plate is unnecessary. Throw it away and bolt rectifiers on bottom plate.
Old 8th July 2012, 09:53 AM   #25
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Idiot just saws plate in two, as in circus.
(bigger idiot stacks toroids, then makes conductive circle for even prettier fireworks)
Fat mounting plate with thin ground wires is cool.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 8th July 2012, 01:03 PM   #26
Uunderhill is offline Uunderhill  Canada
A person sees themself by projecting their personality onto others, and then watches the reflection come back.
Old 8th July 2012, 01:20 PM   #27
Zen Mod's Avatar
naah
everyone knows that Jacco is always writin' looking at mirror
that's the reason why his posts you always must read through thick and pink glasses
Old 8th July 2012, 01:42 PM   #28
Gentlemen,
Thanks for pointing out a Shorted Turn.
Is this the problem ?
Shorted Turn - is a closed loop around a magnetic field, which can get a massive current induced into it
Can a magnetic field induce a current in aluminum and stainless steel ?
However, could the magnetic field induce a current in the ferrous washers - which would then be conducted by the aluminum loop ?
To be on the safe side - I should break the loop.
Mounting diode bridges on top of the donuts is a technique I've seen on a few amps (with a single donut).
Old 8th July 2012, 03:05 PM   #29
juma is offline juma  Germany
juma's Avatar
Originally Posted by Uunderhill View Post
... Can a magnetic field induce a current in aluminum and stainless steel ?...
Do they conduct electricity ?
Old 8th July 2012, 03:13 PM   #30
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Underhill
Hot glue you mention is not the best way to secure those caps. I have done this before and overtime they can knock off easily. This side of mounting brackets pure silicone is superior every time to any type of hot glue sticks
David
Help with F5 with Gamut style MOSFET'sHide this!Advertise here!
Gamut D200 clone !!! ANALOG GUY Solid State 72 1st July 2017 12:30 PM
Gamut amplifier jouch Solid State 24 15th August 2012 06:44 PM
DIY home etched boards, old style, simple, fast and SMD style destroyer X Solid State 51 11th April 2011 09:07 PM
Gamut audio ben goh Pass Labs 14 5th March 2007 10:32 AM
gamut amp brian t Solid State 1 10th August 2002 11:37 AM
