#11 |
Do I spot a shorted turn between the transformers and the aluminum plate connecting them via the mounting bolts?
#12 | |
I stole the idea of gluing the electrolytics down with a hot glue gun and using P to P wiring from the Blue Circle BC 1022 amplifier. P1010474 | Flickr - Photo Sharing! However, if I were to do it again, probably would have used an FR-4 board with a focused ground area. But hind site is wonderful. Also, I would have BOUGHT A PRE MADE CASE !!! instead of making it. However, mounting the 2 toroids in the back of the amp worked out well - resulting in running short AC lines inside the amp. I was a bit concerned about in rush current when the amp was switched on so dual power switches were installed. The technique of mounting the bridges above the power toroids seems to be pretty common. The green wires running from the diode bridges are connected to the ground focus point. The Mundorf film caps focus in on that node too. . Last edited by Uunderhill; 7th July 2012 at 06:06 PM. |
#13 | |
There is a rubber washer - then the toroid's metal washer - and the aluminum plate sits above that. So the aluminum plate sits at least an 1/8" above the windings. . Last edited by Uunderhill; 7th July 2012 at 06:14 PM. |
#14 |
think more
if screw heads have connection with base plate , then also with Al plate on top - you have shorting turn through both donuts
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#15 |
ah, now I know why it sounded better once I tried to isolate the mounting screw from chassis
![]() hey, btw, it also sounds better using brass screws, it really does ![]() |
#16 |
brass screws are also conducting AC current
so - you screwed something else , if that worked better
#17 |
non magnetic
btw, how is it conducting anything if its totally isolated from anything else, with isolators ? |
#18 |
#19 | |
Both the case and the aluminum plate are at the same voltage potential. The donuts are electrically insulated from the case by the large rubber washer on both the top and bottom, supplied by Antek. Do you mean the donuts are talking to each other through the stainless steel mounting bolts ? I thought the idea of the donut was that all the flux lines stayed inside the core ? Can stainless steel be picked up by a magnet ? Do they make 5/16" nylon bolts ? Last edited by Uunderhill; 8th July 2012 at 12:59 AM. |
#20 | |
A 1" diameter neodymium magnet has a just a hint of a pull on a bolt (machine screw ?) made from 304 stainless steel. Do you you think the donuts are talking to each other by inducing a current in the stainless bolts ? |
| Gamut D200 clone !!! | ANALOG GUY | Solid State | 69 | 16th August 2012 04:19 AM |
| Gamut amplifier | jouch | Solid State | 24 | 15th August 2012 06:44 PM |
| DIY home etched boards, old style, simple, fast and SMD style | destroyer X | Solid State | 51 | 11th April 2011 09:07 PM |
| Gamut audio | ben goh | Pass Labs | 14 | 5th March 2007 10:32 AM |
| gamut amp | brian t | Solid State | 1 | 10th August 2002 11:37 AM |
