Help with F5 with Gamut style MOSFET's
Old 1st August 2012, 12:05 PM   #101
Uunderhill is offline Uunderhill  Canada
Looking at Mr. Pass's equations, for MOSFET with a high Z output stage (common source ?)
To lower Zout, the real options are:
- decrease the output source resistor
- increase F.B.
- or find a MOSFET with a low gm
Minimizing Zout is a real balancing act.
The "bricks" have a gm = 90 A/v,
So I'm thinking of going back to an Aleph style amp - but biasing it at only around 1 amp - but minimizing Zout.
I dropped the Aleph style amp only because of the power dissipation and heat.
Having a current source at each stage, has some great advantages.
Old 1st August 2012, 12:12 PM   #102
Originally Posted by Zen Mod View Post
without curves and specific data , it's inevitable that you must do some measuring
so - either measuring xconductance of mosfets (Papa's papers 0n FW site - Mosfet Testing ) or measuring output impedance directly
Yes, I was thinking of connecting some output resistors to the F5, measuring the change in Vout and then plot a load line.
But the Zout equations really help to understand the amp.
Old 1st August 2012, 03:39 PM   #103
gl is offline gl  United States
You could also parallel more output transistors. However, lowering the current through each output transistor to keep the efficiency up also lowers the transconductance for each one, raising the total output impedance. No free lunch. I've been playing around with this idea myself recently. I suspect I'm not telling you anything you don't already know.
gl
Old 1st August 2012, 03:48 PM   #104
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
xconductance will go double with double outputs
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 1st August 2012, 04:55 PM   #105
Only if the current stays the same.
In the above post I said that if you reduced the current per transistor to gain efficiency then the transconductance would drop.
gl
Old 1st August 2012, 06:15 PM   #106
Zen Mod's Avatar
one step back , two in front
anyway - capacitance will rise it's ugly head then
Old 1st August 2012, 06:31 PM   #107
Yup. No free lunch.
Old 5th August 2012, 03:23 PM   #108
Had one step forward here.
Found this good article* which discusses HEXFET's in audio output stages.
There is a ton of good info in this article.
The author says because of HEXFET non linearities, a gate needs to be driven with as much current as possible to maximize linearity.
However, he doesn't look at Ciss - but instead looks at the Gate Charge.
He uses the equation I = 100 * Qg * f(max)
Turns on for a bread and butter IRF 240 Qg(max) = 70 nC
While for a Brick Qg (max) = 380 nC
This helps to explain why 3 jFET's have the poop to drive a Brick.
I would add that most datasheets show a Gate-Charge curve.
On the curve, there is a charge plateau, that is well below the max values.
* Using HEXFETs in High Fidelity Audio
http://www.irf.com/technical-info/appnotes/an-944.pdf
Old 5th August 2012, 04:32 PM   #109
Originally Posted by gl View Post
Yup. No free lunch.
GL,
Recommend you print a copy of this - its quite a good article.
He points out that for a MOSFET Rds(on) does increase with temperature.
However, Vgs(on) has a negative Temp co efficient -1mV/oC to -1.5mV/oC
and this is why MOSFET's are prone to thermal run away.
This explains why Mr. Pass put the thermistor in parallel with Vgs.
In fact, you'd think someone would make a component that has a complementary temp co efficient to Vgs
But the best comment from the article is Compromise will be almost essential
Old 5th August 2012, 04:49 PM   #110
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
All of that is more related to switching circuits.
As is Rds(on), relevant for switch mode stuff, but is of no consequence for conventional audio amps.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Help with F5 with Gamut style MOSFET'sHide this!Advertise here!
Gamut D200 clone !!! ANALOG GUY Solid State 72 1st July 2017 12:30 PM
Gamut amplifier jouch Solid State 24 15th August 2012 06:44 PM
DIY home etched boards, old style, simple, fast and SMD style destroyer X Solid State 51 11th April 2011 09:07 PM
Gamut audio ben goh Pass Labs 14 5th March 2007 10:32 AM
gamut amp brian t Solid State 1 10th August 2002 11:37 AM
