Amp Camp Amp - ACA - Page 73 - diyAudio
Old 14th January 2013, 10:31 PM   #721
Danger Mouse's Avatar
Yes its Block trafo from reichelt.
I take the 50VA 24V version. This gives me ca. 30V unregulated Rails.
Because i want to regulate the voltage like in zen var. 3 --> this is the next step
In the moment i burn the voltage down with resistors to desired level.
Works really well but resitors run a little bit hot.
If you would do it without active regulation, probably 15V secondary should be ok.
correct me if i`m wrong ---but this should give ca. 19V at the supply
greets alex
Old 15th January 2013, 12:03 PM   #722
JRKO's Avatar
Send a message via AIM to JRKO
Question for you more technical types:
My vanilla ACA will be driving 109dB/W/m horns and I'll be using Lpads on the speaker level to bring them in line with the the bass output. I also need a vol pot for gain matching. What pot value should I use 50k/100k etc etc?
tnx chaps
James
If I'm not making noise, I'm making something to make noise
Old 15th January 2013, 12:47 PM   #723
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
lowest ; you didn't read last severalposts ?
10K
btw - if you're feeding just one way with ACA , L-pads are redundant (and bad for sound) , having pot in front of ACA
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 15th January 2013, 01:44 PM   #724
JRKO's Avatar
Aw rats. I searched 100k, 50k & 25k but not 10k!! tnx ZM
LPads were recommended by Pano but will be the fixed (calculated value) type
now to find a good stereo 10k pot
Old 15th January 2013, 01:58 PM   #725
Zen Mod's Avatar
repeat : if you have pot in front of ACA , you don't need attenuation right in front of driver
any sort of L-padding ( variable or fixed ) will kill the grunt
try , listen and then decide
Old 15th January 2013, 02:51 PM   #726
JRKO's Avatar
when you say 'one way' do you mean full range? because my ACA will drive highs and another amp the lows?
Old 15th January 2013, 02:54 PM   #727
Zen Mod's Avatar
I meant as you wrote - one amp (channel) - one driver
having two attenuators in chain is same as having two steering wheels in car ; leave one which is less influent ( in a bad way)
in car - leave either your , or wifie's
(depending who's better driver)
Old 15th January 2013, 02:57 PM   #728
JRKO's Avatar
Oh, okay.
Pano's reasoning was this - "Horns are very efficient. That means all the hiss, hum, buzz, rizz, etc. that you don't notice on normal speakers will be plenty obvious on the horns. Dropping the horn's level 6-12dB will get the amp's output up out of the dirt. Yes, you'll need more power, but that's rarely a problem in domestic settings."
Old 15th January 2013, 05:00 PM   #729
bcmbob is offline bcmbob  United States
This pot is very good and preferred over the Alps Blue by many users. I consider it a real bargain. It is not top build quality but the performance is excellent.
DACT Type 21 Stepped Attenuator
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 15th January 2013, 05:47 PM   #730
JRKO's Avatar
I've gone with this one - 500K Tocos Cosmos RV24 Stereo Potentiometer Hifi Collective - lesser than Nobles wtc but a step up from Alps Blue Beauty
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 43 24th October 2016 04:09 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
Copyright ©1999-2017 diyAudio
