Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 30th December 2012, 06:43 AM   #701
billyk is offline billyk  United States
billyk's Avatar
Originally Posted by bcmbob View Post
General question
I'm curious about how many are using a preamp/gain stage with the ACA as opposed to a pot or other attenuation device for volume control.
ODAC -> B1 buffer in front of mine.
Old 30th December 2012, 08:22 PM   #702
waam68 is offline waam68  United Kingdom
General question
I only have a Yaquin MC12B phono/pre so I build all my amps without a pot and use the one on the Yaquin. My ACA drives my big old 15ohm wharfedales pretty loud but then again my listening room is only about 15 by 15ft. The ACA goes noticibly louder than my 3.5w tube SET with better grip on the bass. Really lovin this little amp in my system with vinyl.
Mike
Old 31st December 2012, 04:55 PM   #703
MEGA_amp is offline MEGA_amp
MEGA_amp's Avatar
Default question on bias - 3x
I've run this amp with double bias for some time now, and my sinks are having no trouble keeping up. I'd now like to triple the bias. For double bias I simply halved the values for R1-R4. For 3x bias, is it simply a matter of taking those values and dividing by 3? And, do I need to adjust the feedback loop (R11-R12) for any reason when upping the bias? I'll be running this to Tony Gee's Solo 103 for near field listening, also building a Pensil 10.2, not sure if this thing will drive the Alpair 10.2 though, will be experimenting.
Any input would be appreciated!!
Thanks......HAPPY NEW YEAR!!!!!!!!!!!!
-John
Old 31st December 2012, 05:13 PM   #704
bcmbob is offline bcmbob  United States
Ma - can you report on how that bias change effected the sound/output of the ACA?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 31st December 2012, 06:45 PM   #705
MEGA_amp's Avatar
I would highly recommend increasing bias; as to the sound, all I can say is that it was just better. My little inefficient bookshelf speakers certainly presented a bigger soundstage. Nelson typically advocates maximum bias for best sound, and based on my experience building many of his designs over the years, I tend to agree.
Old 31st December 2012, 08:02 PM   #706
Loudthud is offline Loudthud  United States
Loudthud's Avatar
MA, I would suggest you keep an eye on the power dissipation of the resistors. It might be better to just parallel several to get the value down.
The open loop gain of the ACA would increase at higher bias currents. Nelson likes to keep feedback at 10dB to control higher order harmonic generation so open loop gain needs to be measured. I'll do some experiments in the next week.
Old 31st December 2012, 08:26 PM   #707
MEGA_amp's Avatar
Originally Posted by Loudthud View Post
parallel several
Threw a few 10W on there. At 2x bias, they're lukewarm.
Concerning the feedback, I'm fairly clueless on this adjustment, so your input would definitely be helpful. I'd like to go no feedback....is it a matter of just putting a jumper at R11, and completely removing R12?
Old 31st December 2012, 09:34 PM   #708
Loudthud's Avatar
That should get the job done.
That will work. I left R11 in place just for a little protection against ESD. THD can be lowered by tweeking the R1-R2/R3-R4 ratio and adding a Source resistor to Q1. (Search for my earlier posts in this thread.) But, in such a simple design, there are unintended consequences. I don't know if it will sound any better. As is it really warms up (pun) the sound of my cheap CD player.
Old 3rd January 2013, 10:22 AM   #709
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Amp Camp Amp - ACA
Any ETA on the next round of boards?
/U.
Old 3rd January 2013, 11:54 AM   #710
overtheairbroadcast is offline overtheairbroadcast  Canada
/U.
See post #695 from Variac.
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
