Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 5th December 2012, 01:18 PM   #641
bcmbob is offline bcmbob  United States
Originally Posted by fastbike1 View Post
I do find no small irony that Nelson designed this amp to be a great performing, SIMPLE design, delivered same and yet folks just can't resist "messing" with the amp.
Seems to me that if you want more you ought to be building an F5 Turbo.
I resemble that remark
My query about the PC power supply was prompted more by a desire to save a few pennies by using what's on hand - if possible. Also have a chassis design that would aesthetically benefit from not using a brick. The only way I know how to get an answer is to ask a question. I would suspect any designer would allow some tweaking. If not - we wouldn't see version numbers on PCBs.
In my case, the ACA is an introduction to something other than LM3886 based amps. It's a journey I've been contemplating for about three years. With that in mind, I have ordered and am expecting delivery on a F5 design based kit as a next step. Had a couple nice phone conversations with the folks at PassDiy and 6L6 about where to go after that - if necessary.
So I'm looking forward to this new adventure and am already thrilled at the quick and informative responses found in the "House Heater" community.
P.S. I do have two 18.5V laptop bricks I will use for the initial build. Plus - the Peter Daniels PCBs are on the way. If not here, they will be put to good use with other projects.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 5th December 2012, 05:30 PM   #642
OOps! I didn't order any mica pads as I'm used to the insulated LM3886TF chips. I do have a supply of thermal insulating tape left over from some computer projects. Will that be sufficient? It's 10 mils - maybe two layers?
BTW: Has anyone pointed a laser thermometer at the ACA when in full operation?
Bob M.
Old 6th December 2012, 04:20 PM   #643
uvellani is offline uvellani  United States
Using an 8x3" heatsink similar to the one in the diy store, I found that it runs pretty hot. It was 48 deg C on the chip and around 35 deg on the sink after about a couple of hours. Wonder what it will be like in the summer. I would suggest using a bigger sink for this.
-uv-
Old 8th December 2012, 05:17 AM   #644
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Amp Camp Amp - ACA
I think it's just great t hat people mess with this amp. They might learn some stuff. My only concern would be that people might assume that it NEEDS to be modified, and that's not true at all. Just build it stock and you'll be amazed. Mess with it and you'll have some fun and it might sound even better to you..
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 8th December 2012, 12:20 PM   #645
billyk is offline billyk  United States
billyk's Avatar
Oh yes, exactly! Stock just as it comes is really wonderful.
As soon as I finish putting it together I will get some more parts and start to play with it. There lots of good ideas in this thread. Plus I will have something to listen to while I experiment!
Old 8th December 2012, 04:22 PM   #646
bnorrish is offline bnorrish  United States
bnorrish's Avatar
I do not think it needs to be modified in terms of sound. I am very impressed. Not really pretty sitting in my office. I thought up putting it in a nice chassis, PSU board and transformer, etc. Started adding up the costs and thought it would be better to invest in an F5 build. This amp did stoke my obsessive compulsive behavior and it got me hooked on a new hobby! The UPS man keeps coming and wife keeps asking "How much is this all going to cost?"
Old 9th December 2012, 04:10 AM   #647
Samuel Jayaraj is offline Samuel Jayaraj  India
It might help every enthusiast here if someone could give a detailed comparative sonic report between ACA and F5.
Sam
Old 9th December 2012, 06:17 PM   #648
Shucks. I ordered 0.68 ohms @ 2 watts instead of 3 watts for R3-4. Can I use them till I get the proper pieces.
Don't like green smoke !!
Bob M.
Old 10th December 2012, 12:09 AM   #649
Initial impressions after a week or so of playing it through a full range speaker(Alpair 7.3 in a BIB). The sound is closer to my Aleph 3 than the F5. Warmer, better mid-range etc. But ultimately it did not measure up to my SET2A3 into the same speaker. The SET actually had better extension -both upper and lower- than this amp which was surprising.
But it is a great little amp and dead quiet. It is going to be the center piece of a smaller system that I plan to put together for near field listening. And off course I have to try a non-smps to see what that sounds like.
I think that is one of he charming things about this amp. I slapped it together in a couple of hours once I had the boards from parts I had lying around including heat sinks and laptop power supplies. It is a nice little diversion from the all the other bigger projects that await me in various stages of incompletion - speakers, amps, dacs, cd players, turntables and I don't know what else. So many things to build, so little time!!!
-uv-
Old 10th December 2012, 03:53 AM   #650
Loudthud is offline Loudthud  United States
Loudthud's Avatar
They should work fine.
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 53 17th February 2018 05:04 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
