#611 |
diyAudio Editor
In fact some of the kits have 50v caps because we had them.
Your substitution would be a tiny upgrade! |
#612 |
Does anyone know the source for the Amp Camp's
surplus aluminum? or an alternate surplus Al source? |
#613 |
Check out Metals Depot
Bob M. "Arrange Whatever Pieces Come Your Way." |
#614 | |
#615 |
Thank You Loudthud...leave off R1 and R3..so obvious...now. Are you using this for headphones? I could try the IRF510 as I have them, I read the data sheets, just don't always know what it means... I also have a lot of IRFZ46N.....
#616 |
Like most folks, I have a box full of wall warts and bricks, several surplus PC power supplies and a couple spare 22 V toroids. I understand that NP designed the ACA with simple PS requirements - but I'm curious if anything has shown itself to be preferred/optimum for this amp.
Also, as PC PSs provide primarily 5 and 12 volts, are there any mods necessary them match it up with the ACA?
#617 | |
diyAudio Editor
The ACA is designed to operate with 19v and 2A per channel. Lots of laptop bricks are rated at 19v, anything over 2 amps is fine, or, obviously 19v, 4a for 2 ch. Conventional PC power supplies that go in a PC chassis aren't too useful for this.
If you haven't read his article in the articles menu in the blue band at the top of every page I'd suggest loking it over. It's full of good info. Quote:
2013 Burning Amp Festival announced: Sunday, October 6th in S.F. We need Volunteers & sign-up's for what you're bringing! Last edited by Variac; 3rd December 2012 at 09:07 PM. |
#618 |
diyAudio Editor
A surplus scrapyard in Santa Rosa , California. If you live close to there PM me.. the heatsinks are from http://www.heatsinkusa.com/
8.460 x 5" was more than enough per channel
2013 Burning Amp Festival announced: Sunday, October 6th in S.F. We need Volunteers & sign-up's for what you're bringing! Last edited by Variac; 3rd December 2012 at 09:06 PM. |
#619 | |
#620 | |
I'm using a smallish bookshelf two way reflex speaker with a first order crossover. The low damping factor of the ACA gives a nice bass boost to the 4 inch woofer. I don't know what to expect with headphones except a loud turnoff thump. Playing with R1-R2/R3-R4 resistors changes the distortion quite a bit. It also changes the gain. It's a lot like the PLH amp. Nelson discusses the tradeoffs in his article. Link: http://www.passdiy.com/pdf/PLH_amplifier.pdf Note: IRF120, IRF520 and IRFZ46 won't fit the ACA PCBs, you'll have to improvise. |
| Amp Camp Amp #1 | Nelson Pass | diyAudio.com Articles | 27 | 7th December 2012 09:27 PM |
| Amp Camp! | Jason | Site Announcements | 2 | 30th June 2012 02:57 PM |
| Best D camp config for Tweeter amp | Zero One | Class D | 0 | 24th February 2010 04:57 AM |
| better the Pass camp? | rick57 | Tubes / Valves | 6 | 26th March 2005 06:04 AM |
