Amp Camp Amp - ACA - Page 61 - diyAudio
Old 30th November 2012, 05:04 AM   #601
neoinc is offline neoinc  Singapore
neoinc's Avatar
I am using a Pensil for Alpair 6.
Old 30th November 2012, 06:21 PM   #602
billyk is offline billyk  United States
billyk's Avatar
Glad to hear you like the combination. I just received my mMar-Ken6p kit from Dave and can't wait to get them built and give them a listen!
Old 1st December 2012, 03:41 AM   #603
neoinc's Avatar
It sounds warm, detailed with good bass in a small room. I thought it is well match with ACA.
Old 1st December 2012, 02:14 PM   #604
Default Heat sinking
What temp does the standard heat sink that comes with the kit generate? I have a pair of 4.5"x4.5" sinks with 1" fins. I was wondering if I could get by with those?
-uv
-uv-
Old 1st December 2012, 03:23 PM   #605
jan.didden's Avatar
1A at 20V is 20W of course.
The temp rise above ambient depends on your heatsink.
From your data I would *guess* its an about 1degree C/watt heatsink which means it will have about 20 celcius temp rise.
But also depends on the heatsink orientation - flat, upright, that sort of thing.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 2nd December 2012, 01:03 PM   #606
bcmbob is offline bcmbob  United States
Hi, I'm an Amp-Camp nubee who just received two PCBs and am placing a parts order. This may have been answered earlier in the thread but I haven't read it all yet. I have several 3300uf 50V caps from a mis-order. Can I use these instead of the 35V spec on the BOM?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 2nd December 2012, 01:13 PM   #607
6L6 is offline 6L6  United States
6L6's Avatar
Yes, you certainly may, they will work very well.
The voltage rating on a capacitor is a maximum, running it at a lower voltage has no downside, and will increase it's life as the cap is having an easier time.
Old 2nd December 2012, 01:48 PM   #608
Thanks 6L6. Thought so but needed confirmation.
Sending PM
Bob M.
Old 2nd December 2012, 01:54 PM   #609
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
though lower voltage caps can have more capacitance for the same size(and money), higher voltage caps sometimes have better resistance specs(low ESR)
anyone seen the flat pack Cornel Dublier caps
Old 2nd December 2012, 08:48 PM   #610
Congo5 is offline Congo5  United States
Hi all, new here. I ordered boards and parts from Mouser today. I want to use this for headpones, othodynamic Fostex T-50's. I am new to DIY amps, but have read this thread, have built several CMOY's and have some background with electricity. HVAC, automotive, computers. These phones are rated at 3000mw. I measured a 1k sine wave from BK Precision 3020 modded t-50's....3.23v=104db * ** 4.14v = 110db so if math is correct 3.2v squared divided by 50ohms is 204mw .. 4.14v would be 342mw. If I understand the formula.... I can double R1,R2,R3,R4 and have enough power and a lot less heat. So I ordered extra 3W 1ohm and 1.3ohm resistors. If there is interest I can document the build and post it. I have an oscilloscope but can only do basic things so far... Thanks
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 43 24th October 2016 04:09 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
Copyright ©1999-2017 diyAudio
